Old 10-08-2012, 11:10 PM   #29
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by Unleashed View Post
It doesn't really matter if it's placebo effect or not, it makes the car feel more fun to drive to me and thats all that matters.
Appreciate all the comments
Your right! Haters gonna hate
Enjoy your mods
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-09-2012, 12:27 AM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by illusivema70 View Post
explain? not challenging you, simply would like to gain some knowledge.
also can you say
Prius tires, like mentioned above, manufacturers are constantly bidding for contracts, buying tires for FRS only would cost more than buying for both. simple business practice.
The braces simply won't change body roll, they may reduce chassis flex but even that is debatable as it hasn't been proven by anyone on this chassis yet as far as I've seen.
So, because it won't change body roll his other observations become just as void IMO.
as for hating, it's his car and he can do what he wants, but lets try to avoid misinformation that could cause people to dump a bunch of money into parts for no gain.
I do believe some braces MAY be beneficial on this chassis, but I want to see some proof before I buy. Hopefully nameless will test it eventually
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-09-2012, 12:57 AM   #31
coyote
coyote's Avatar
Drives: Slowly
I would love to see some measurements of chassis flex at various loads points of this chassis (with and without bracing).
If that was on a 300hp car with sticky tyres and upgraded suspension and bushings, all the better.
Bracing can make a massive difference, but the only effect it can have on body roll is to actually increase it.
coyote is offline   Reply With Quote
Old 10-09-2012, 08:22 AM   #32
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Would you please explain that?
Old 10-09-2012, 03:01 PM   #33
wparsons
wparsons's Avatar
If you take away chassis flex then the suspension is forced to do more of it's job, which means the force that used to be flexing the chassis is now force being handled by the suspension. In a corner that would mean more work being done by the outside shocks/springs, and since they haven't become stiffer automatically they'll be compressed more meaning more body roll.
flickr
Old 10-09-2012, 03:17 PM   #34
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Just read this: http://grassrootsmotorsports.com/articles/lean-less/
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2015, 07:32 PM   #35
N234
N234's Avatar
Drives:
Grimmspeed claims in slalom tests, their strut tower bar reduced strut tower deflection from 0.18-inch to 0.03-inch (http://www.grimmspeed.com/strut-tower-brace-brz-fr-s/). Whether or not that is true or exaggerated is not my point, just fyi.
The stiffness allows the suspension to do it's job, and chassis flex MAY lessen the effectiveness of the factory sway bar.
That said, unlike the Grimmspeed, the Cusco bar is hinged, so one can expect it to work slightly less effectively.
To the OP and supporters, you can say it feels stiffer and more responsive and you're likely correct. You can say it feels like it rolls less and I believe you to be honest. It does feel that way to you... but a strut tower bar doesn't directly serve that function.
Unless your sensitivity to body roll has a resolution of <0.15-inch or better. :respect:
N234 is offline   Reply With Quote
Old 02-11-2015, 07:35 PM   #36
N234
N234's Avatar
Drives:
Seconded.
Edit: Never mind. I just read wparsons' post
Eeeedit:
Sorry.... Two year old thread...
Old 09-11-2021, 02:00 PM   #37
DirtyHarry96
Drives: 2014 Toyota 86 TRD
is the underbody plastic panel removed permanently? did the ground clearence affected? i dont want the car scrap its braces xDD
DirtyHarry96 is offline   Reply With Quote
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 05-26-2015 11:39 AM
Carbing Chassis Braces ttknf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 08-14-2012 05:04 PM
Coilovers, swaybars, chassis braces and more! No Limit Motorsport Brakes, Suspension, Chassis 0 08-05-2012 11:31 AM
strut tower braces made out of bamboo?!? aspera Scion FR-S / Toyota 86 GT86 General Forum 26 04-02-2010 01:27 PM
