Old 09-24-2012, 04:50 PM   #29
RYU
RYU's Avatar
Drives: really slow...
Originally Posted by avp1 View Post
Yes you are.
Excellent! New car for me (and my other CA brothers) in a few years from Subaru & Scion
RYU is offline   Reply With Quote
Old 09-24-2012, 05:33 PM   #30
empower-auto
Kouki-Monster
empower-auto's Avatar
I got 38mpg on the highway with 94 Octane E10 in my car. Just saying.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-24-2012, 05:35 PM   #31
jeebus
Drives: 2015 Mustang GT (on order)
pretty much every dealer puts 87 octane in everything because they are careless morons. It isn't the best for the car but it won't really matter either. Once it's yours, put 91+ in. Before it's yours, just pretend all those crappy fillups never happened.
jeebus is offline   Reply With Quote
Old 09-24-2012, 07:52 PM   #32
be6sti
be6sti's Avatar
Drives: 2013 scion frs
..... I live in Iowa..... Everything has ethanol
"Fuck it lets go!"
be6sti is offline   Reply With Quote
Old 09-24-2012, 09:21 PM   #33
Griffdawg
Drives: 2013Scion FRS, 02 Shitty PT Cruiser
I dont think 87 will hurt it at all, I had a 1994 Supra Stock motor, requires premium gas, I bought the car is 1998 and I only used 87 octane in it, runs fine and no knocks and I had over 200,000 miles on it when I sold it a few years ago.
But with the High 12.5-1 compression ratio i wouldn't use anything less than 89.
Griffdawg is offline   Reply With Quote
Old 09-24-2012, 09:28 PM   #34
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by RYU View Post
Using 87 will not destroy your motor or cause it to knock. The manufacturers suggest 91 because it is tuned to the advertised hp/tq/mpg numbers at that octane rating. The factory knock sensors and O2 sensors will tune down your timing and other factors to run on 87. You may not achieve the full 199.9hp on the FA20 but it will not damage your car.
In other words, lower octane will decrease performance but not be detrimental. Would I run it for the long term? No.
THIS is the correct answer.
Old 09-24-2012, 09:47 PM   #35
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
Ditto! My step father works for Toyota at the National HQ in Torrence, CA, and is one of head parts managers. He stated the exact same thing as RYU did. Scion legally has to say only use whatever octane was used to get the performance and MPG numbers. It wont hurt the vehicle at all but could possible deminish performance and decrease MPG slightly. Everyone else are idiots and clearly have not done their homework.
ThaBigUnit is offline   Reply With Quote
Old 09-24-2012, 10:33 PM   #36
ESC POD
ESC POD's Avatar
Drives: Sterling Silver BRZ
With nearly 12.5:1 compression...Premium Fuel is the Only Fuel I will use.
Activating: ESC POD...let's Drive!!
ESC POD is offline   Reply With Quote
Old 09-24-2012, 10:46 PM   #37
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Found some info in the manual published by Subaru on the BRZ.
Premium non-ethanol ONLY!!! It makes a huge difference.
●Use only gasoline containing a maximum of 10% ethanol.
DO NOT use any flex-fuel or gasoline that could contain more than 10% ethanol, including from any pump labeled E15, E30, E50, E85 (which are only some examples of fuel containing more than 10% ethanol)
●If you use gasohol in your SUBARU, be sure that it has an octane rating
no lower than 93 AKI.
●●SUBARU DOES NOT recommend the use of gasoline containing methanol
■SUBARU recommends the use of cleaner burning gasoline
Cleaner burning gasoline, including reformulated gasoline that contains oxygenates such as ethanol or MTBE
(Methyl Tertiary Butyl Ether) is available in many areas.
SUBARU recommends the use of cleaner burning gasoline and appropriately blended reformulated gasoline. These types of gasoline provide excellent vehicle performance, reduce vehicle emissions and improve air quality
Slightly off topic... What is the highest octane fuel you can benefit from on a stock tune?
■Fuel types
Unleaded gasoline (93 AKI [Research Octane Number 98] or higher)
If unleaded gasoline with an octane rating of 93 AKI (98 RON) is not available,
unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
used with no detriment to engine durability or driveability.
Old 09-24-2012, 11:07 PM   #38
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thank you! Great Information! Clearly You did your home work!
Old 09-24-2012, 11:10 PM   #39
sierra
Drives: Skoda Yeti DSG diesel 4x4
If he knew what he was talking about he would have told you that anything under the 93 octane will 'definitely' diminish performance and also reduce fuel economy, not 'possibly'.
The engine is detuning itself to cater for the lower octane in proportion to the level it needs to go to avoid damage. It was never designed to run like that.
Have a word with someone in the service department instead of spare parts.
Has anyone got some dyno figures to show how much power is lost?
sierra is offline   Reply With Quote
Old 09-24-2012, 11:34 PM   #40
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
87 octane will not cause knock...but 87 octane is more prone to knock. This starts to become more serious as compression rises..and at 12.5:1 CR..its a number thats enough to worry about.
short term knock wouldnt worry me, and the ECU will pull enough timing to compensate. But its another matter that the wear and tear of the internal components of the engine are already accelerated before the car even has its first owner.
detonation is detonation regardless if its big or small, and id prefer to know that when i go into a dealer, the car is in tip-top shape.
WingsofWar is offline   Reply With Quote
Old 09-24-2012, 11:45 PM   #41
sierra
87 octane in an engine that's built and tuned for 93 octane, especially with 12.5:1 compression ratio certainly will cause knock and almost certainly detonation if it's pushed with resulting piston failure.
The only saving grace is having knock sensors that dramatically retard the ignition and no doubt fuel too. Without that these engines would be toast.
Just read that dropping from 98/93 to 95/91 loses 5% torque due to the knock sensors retarding the tuning.
So we might speculate that 91/87 = minus 15% but I would imagine the loss for the lower octane would be even greater since the engine is going way outside it's design parameters.
There was a recent post where a new owner was disappointed with the performance of their new 86/BRZ and it might well have because the dealer put low octane fuel in it?
Old 09-25-2012, 02:10 AM   #42
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
Originally Posted by Sirnice View Post
I went for a test drive over the weekend (FR-S) and stop by the gas station for a fill up. I saw the sales guy reached for the cheapest gas and i pointed out to him the gas door label says "Premium gas only" and he responded that they put regular gas in all their cars (even the higher end Toyota V6 engines).
Is it ok to put regular gas instead of following factory recommendation?
NO.
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
Gas Premium or regular? Dragon86 Scion FR-S / Toyota 86 GT86 General Forum 315 06-20-2017 10:14 PM
FRS arrival for regular customers question NWIguy Scion FR-S / Toyota 86 GT86 General Forum 20 05-05-2012 08:54 AM
Anyone have a pic of the regular seats? DuMa Scion FR-S / Toyota 86 GT86 General Forum 38 12-14-2011 12:29 AM
So is it a hatch or regular trunk? xantonin Scion FR-S / Toyota 86 GT86 General Forum 5 12-09-2011 07:26 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 12:52 AM
