#15 |
Drives: 2013 Subaru BRZ Limited (WRB MT)
#16 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
I think my car had 87 from the dealership. After my first fuel up, it seemed to wake up the engine a lot. I'm not sure if the reason for poor initial performance was a break-in issue or 87 octane, but it's had nothing but 93 since then and runs great.
Also, after switching to Shell gasoline, the bird chirping under the hood is all but gone, which was a nice surprise.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
#17 |
Drives: really slow...
Using 87 will not destroy your motor or cause it to knock. The manufacturers suggest 91 because it is tuned to the advertised hp/tq/mpg numbers at that octane rating. The factory knock sensors and O2 sensors will tune down your timing and other factors to run on 87. You may not achieve the full 199.9hp on the FA20 but it will not damage your car.
In other words, lower octane will decrease performance but not be detrimental. Would I run it for the long term? No. |
#18 | |
Drives: Traded BRZ for Supra
#19 | |
6/22/12-2/6/24
#20 |
Kouki-Monster
This car already under-performs on 91 octane fuel. Anything less is seriously risky. With 94 E10 it seems to run fairly well.
Rich Anderson
EMPOWER AUTO |
#21 |
Drives: Asphalt FRS
#22 |
Just don't. The engine will pull timing in order to run on it if your only option were to run regular fuel, but you should never do it unless it is a last resort.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#23 | ||
![]() Quote:
Again, would I do it? No. If it was half the price as 91 I might because i'm not at redline on my commute to work and will not benefit from the added octane as much. |
#24 |
Country Boy 4 Life
Slightly off topic... What is the highest octane fuel you can benefit from on a stock tune?
#25 |
I'd be surprised if a high compression engine such as the FA20 didn't have a knock sensor. So the risk of damage to the engine from detonation is probably slim.
Still, it's obviously not good for the engine in the long-run and you'll get worse gas mileage with the lower octane fuel. |
#26 |
#27 |
Drives: Whiteout FR-S
I feel like i get worse mpg just using fuel with 10% ethanol in it :|
#28 |
You do. I kept track of how much I got out of each tank. Shell 91 Ethanol free gives me between 7-10% better mileage than 94 10% Ethanol. But 94 definitely feels snappier and I get better throttle response.
| Gas Premium or regular? | Dragon86 | Scion FR-S / Toyota 86 GT86 General Forum | 315 | 06-20-2017 10:14 PM |
| FRS arrival for regular customers question | NWIguy | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 05-05-2012 08:54 AM |
| Anyone have a pic of the regular seats? | DuMa | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 12-14-2011 12:29 AM |
| So is it a hatch or regular trunk? | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 12-09-2011 07:26 PM |
| Consequences to Adding Regular Gas? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 12-06-2011 12:52 AM |
