Old 02-06-2013, 05:37 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Easy fix.. change out that F-550 truck size windshield washer res for a normal sized one custom mounted
I laughed when I saw how big that stupid thing is..
Yeah, the FBM kit doesn't come with a smaller one, so I am struggling with getting the pipe, res, and fog light to happily coexist in that area. I haven't filled mine up since I got it, and it was still damn near too full to pull the neck out. I almost drained it all out and put some good fluid in, but I felt that would be wasteful, haha.
Old 02-06-2013, 05:37 PM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by zoomzoomers View Post
How about something like this?
Old M5 wheels were actually designed to cool the brake discs. Ugly wheels.. not sure if they worked or not.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-06-2013, 05:37 PM   #31
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Wow, I never knew how obnoxiously big that washer fluid tank is on our cars! lol
I want a smaller one, lets stir up the vendor pot and get something going!
Old 02-06-2013, 05:38 PM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Accelerated does for their turbo kits, I've seen them do so when I was visiting their shop.
Good luck getting one out of Accelerated, haha. He might ship you an empty box then expect you to send him an e-mail of the missing parts so he can send them to you.
Old 02-06-2013, 05:42 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not sure what's going on there, the only customer issue he had when I was there they took care of quickly. I didn't get any bad vibes from them when I was there. He reassembled his car just so I could go for a ride in it so from what little I've experienced with him it doesn't seem right but obviously the complaints from the two (I think just two?) members are legit.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-06-2013, 05:42 PM   #34
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Correct me if I'm wrong somebody, but I thought that I saw the supposed '14 BRZ STI with some rectangular ducting from underneath the front spliter that ducts cool air to the front brakes.
If you don't want to give up your fogs, that might be a good solution. Just wait a little for it to roll out. Or the aftermarket to duplicate it. From the pics I saw of it, it looked quite nice and neatly tucked under the spliter.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 02-06-2013, 05:43 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The OEM bottle mounts with two bolts, one is visible in the upper right hand corner, and the other is hidden behind the res and you will never find it unless you move the fender liner. That and the bottom post sits in a bracket with a hole like the coolant overflow tank. I would think something that mounts at the bottom in that same hole and a bracket to mount to some other random hole on the subframe would work well. The problem is the filler neck mounts to the top portion so maybe chopping off the entire bottom secion and just leaving that little top area and using the two OEM mounting locations would be best. Sounds like a great business opporunity.
Old 02-06-2013, 05:46 PM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No idea.. I haven't been paying attention to the STI rumors. Now that I have a car and I'm happy with it I don't think I'll be upgrading anyways.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-06-2013, 05:50 PM   #37
ATL BRZ
ATL BRZ's Avatar
The OEM bottle mounts with two bolts, one is visible in the upper right hand corner, and the other is hidden behind the res and you will never find it unless you move the fender liner. That and the bottom post sits in a bracket with a hole like the coolant overflow tank. I would think something that mounts at the bottom in that same hole and a bracket to mount to some other random hole on the subframe would work well. The problem is the filler neck mounts to the top portion so maybe chopping off the entire bottom section and just leaving that little top area and using the two OEM mounting locations would be best. Sounds like a great business opportunity.
Absolutely does sound like a good business opportunity! We should ping some vendors like @Turn in Concepts, @robispec, @GrimmSpeed, @Racecomp Engineering, @FA20Club.com, @Vigilant Motorsports
We're looking to replace the gigantic washer fluid reservoir with something much smaller. To give room for brake ducting, forced induction piping, etc.
The Following User Says Thank You to ATL BRZ For This Useful Post:
swift996 (08-28-2013)
Old 02-06-2013, 06:08 PM   #38
Hanakuso
iirc emptying the wiper fluid would give you a weight saving of 7 pounds. If someone could make a smaller one of 1-2 pounds that would be great.
Hanakuso is offline   Reply With Quote
Old 02-06-2013, 06:38 PM   #39
PRORICAN
PRORICAN's Avatar
I dremmeled my fog housings to get airflow to an oil cooler and possibly brake ducts as well. Here's a couple of pics...
PRORICAN is offline   Reply With Quote
The Following 3 Users Say Thank You to PRORICAN For This Useful Post:
ATL BRZ (02-06-2013), nix (07-24-2013), RallySport Direct (02-06-2013)
Old 02-06-2013, 07:09 PM   #40
ATL BRZ
ATL BRZ's Avatar
Nice! Can you please post a pic of the back of those and maybe the sides? Is there a good amount of material to clamp down a hose?
Old 02-06-2013, 08:17 PM   #41
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Prorican, those look great!
ATL, I have been speaking with the manufactures about getting something made for cheaper, but I think those will come with time as more cars come to the market and more people are wanting to track them.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following 2 Users Say Thank You to RallySport Direct For This Useful Post:
ATL BRZ (02-06-2013), PRORICAN (02-07-2013)
Old 02-06-2013, 08:31 PM   #42
Turn in Concepts
Turn in Concepts's Avatar
Hmmmmm....
Let me think on this.
Turn in Concepts is offline   Reply With Quote
The Following User Says Thank You to Turn in Concepts For This Useful Post:
Custom Brake Ducting. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-09-2012 08:50 PM
Limited gets brake "upgrade" over Premium - Canada only? Sport-Tech BRZ First-Gen (2012+) — General Topics 25 05-15-2012 12:35 AM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
