Old 09-10-2012, 09:18 PM   #29
Spencer Strayer
Drifter in Progress
Spencer Strayer's Avatar
Drives: 2013 Ultramarine FR-S, MKV GTi
Originally Posted by Scooby South View Post
Hello all.. I am the one that owns the car above...Thanks Darren..
Questions??
In all honesty how hard are these to install? Is it as simple as jacking it up, removing the wheels, taking off the stock suspension and replacing it? Does in come with instructions? When I get my frs I was considering on taking it to a shop but I think its round about that time I became a man and did this shit on my own. (Something to note. I'm not a retard when it comes to cars and am good at looking at things on paper, but I have yet to get my hands dirty)
Spencer Strayer is offline   Reply With Quote
Old 09-10-2012, 09:34 PM   #30
cnk
Drives: '13 DGM BRZ Limited
If you have the right tools, it's not difficult. There is a DIY post on how to do it as well.
cnk is offline   Reply With Quote
Old 09-10-2012, 10:51 PM   #31
Spencer Strayer
Drifter in Progress
Sounds good, I'll have to order some when I get mine!
Old 09-11-2012, 09:54 AM   #32
nightfire
Drives: 2013 SWP BRZ Limited manual
One question maybe one of you can answer. I've only done springs and shocks on my car in the past but never coilovers. I've heard when you install coilovers you have to get the car corner-balanced. Did you guys do this? Anything else besides this and an alignment that I will have to get done? Seems like a daunting project compared to just doing springs and shocks :/
nightfire is offline   Reply With Quote
Old 09-14-2012, 10:37 AM   #33
BRZranger
Dont NEED to do corner balance if you drop evenly on corners, but you could, expensive for not much benefit IMO.
BRZranger is offline   Reply With Quote
The Following User Says Thank You to BRZranger For This Useful Post:
nightfire (09-14-2012)
Old 09-19-2012, 07:54 PM   #34
jumbaco
jumbaco's Avatar
Drives: FD
those are some nice coilovers!
jumbaco is offline   Reply With Quote
Old 10-15-2012, 02:52 AM   #35
ebphoto
Drives: FR-S, NA8, S13
anyone have these on their lowest height setting?... if so pictures? ride?
ebphoto is offline   Reply With Quote
Old 10-15-2012, 05:00 AM   #36
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
If your looking for the slam "stance" look the KW ver. 3 are not the coilovers for that.
WillRacer1jz is offline   Reply With Quote
Old 10-15-2012, 08:19 AM   #37
wparsons
wparsons's Avatar
Originally Posted by digital_assassin View Post
With my current wheel and tire setup I am rubbing on the rears when cornering and over bumps and will either roll the fenders more or just raise it up a bit. The rubbing is not digging into the tire so lifting it up an 1/8" may fix it. I am also thinking if I go to a hard setting I may get rid of the rub this way too.
The fenders are pre-rolled for a good portion of the fender, so if you're rubbing at the top of the tire your only options are change wheel fitment, raise it up or pull the fenders slightly.
flickr
Old 10-15-2012, 12:28 PM   #38
ebphoto
i understand that.
just wondering what the lowest setting these can be at while still being decent riding.
the rocket bunny car runs these and im guessing that is the lowest car on these coilovers.
Old 10-15-2012, 02:51 PM   #39
D1cker
Drives: B9 S4/ND2
i understand that.
Ken Gushi's car sits pretty low on these as well.
D1cker is offline   Reply With Quote
Old 04-19-2014, 09:30 AM   #40
newbrz
Drives: Limited Dark Gery Metallic BRZ
Do any of you know where I can find the torque specifications for all the bolt for the install of the coilovers? I want to do it myself but I don't find it anywhere. Thank you beforehand
newbrz is offline   Reply With Quote
Old 06-17-2014, 11:08 AM   #41
f16
Drives: SWP 2014 toyota 86
not sure... I don't think they were at any particular height... Basically I counted threads... I remember going up on the rears quite a bit..like 15 threads.. the front I went up just a bit.. I am a firm believer of parallel arms and other components.. so I adjusted to achieve that.. then fine tuned the rake and alignment...
ALIGNMENT is critical on these cars.. they are very sensitive to the correct attitude on the alignment... to little..they skate all over the place.. to much..they won't turn that well..
Bill
do you have an idea about how much camber u can get with stocker tops in front?
f16 is offline   Reply With Quote
Old 06-17-2014, 05:51 PM   #42
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
^^^ no idea. I have camber plates. But I think with the optional Bolts.. its like -1.3 maybe.
Bill
Scooby South is offline   Reply With Quote
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 05:32 PM
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 06:26 PM
Suspension Review: Eibach Sportline Lowering Springs DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 07-23-2019 09:59 PM
Suspension Review: Hotchkis Sport Springs Nitro22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-23-2016 06:01 PM
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 01:53 PM
