Old 08-28-2012, 07:26 PM   #29
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
Originally Posted by avholic View Post
Does this happen only to manual transmission or even automatics? Mine is manual, ~680 miles. It happened many times but i never got a CEL. I learned how to prevent it by doing slight engine brake when coming to full stop. BTW my vin ends 23xx. Pre 100 miles the engine was really shaky under 2k rpm. Post 100 miles it improved a lot, that i could glide thru traffic jams b/w 2nd and 3rd @1500 rpm like driving an automatic.
I asked the kid tech at subaru who went for brz training. He said the idle issue is normal and behaves that way to lower emission blah blah. If they give me a Kia for loaner when i get my car repaired for this issue, im gonna shove it their a##.
it happens to all FRS/BRZ regardless of transmission
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Hotlava86 is offline   Reply With Quote
Old 08-28-2012, 08:15 PM   #30
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
Originally Posted by gdi2290 View Post
just make sure you grab that extended warranty :/
What good is that going to do, if you are under 30K/3yo anyway?
Its a manufacture warranty case and claim, if they have an official fix.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
Old 08-28-2012, 08:32 PM   #31
Longhorn248
Hook 'em
Longhorn248's Avatar
Glad to see it's at least a known issue and not something they have no idea how to fix. I think many of us knew what we were getting into with first model year purchases, but it still sucks when stuff like this comes up.
Longhorn248 is offline   Reply With Quote
Old 08-28-2012, 09:28 PM   #32
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
I've never had a vehicle towed before, but can't he bend rotors or brake lines clamping the tires like that?
Is that how they normally do it? I use tie down straps similar to that every day and you can put some serious force down with those bad boys.
TOMIMOTO is offline   Reply With Quote
Old 08-28-2012, 10:26 PM   #33
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
I was able to drive it today the brakes did feel a little weird that might of been me forgetting how firm it is (the loaner car had very mushy brakes) they couldn't find anything wrong with my car, so I picked it up went around the block then back because the CEL came up. Needless to say they gave me a loaner car again and will look further into it. I'll definitely have them double check I wouldn't want to have any brake failures just because Sunnyvale Towing
gdi2290 is offline   Reply With Quote
Old 08-28-2012, 10:37 PM   #34
luxmn
First FR-S
Drives: Whiteout MT FRS
i think because this kind of problem can be repetitive, who know if it doesn't act up every 25k miles. For a lot of folks, 30k miles only means a year of driving. If you have extended warranty to 80k miles you have a much much better chance to claim warranty a few times until it's fixed correctly.
luxmn is offline   Reply With Quote
Old 08-28-2012, 10:39 PM   #35
bazi
bazi's Avatar
Drives: 6MT Asphalt FR-S
Dude, I have the same issue like everyone else in the "Warranty section". Bro, I would make sure they can recreate the codes and fix it properly. You are lucky to drive it for 700+miles. I got my car at 8 miles and the CEL and SL came on at 25mile! Had the car for one freaking day and now it is at the dealership.
bazi is offline   Reply With Quote
Old 08-28-2012, 11:21 PM   #36
gdi2290
gdi2290's Avatar
ouch, 8 miles. that's insane I remember people talking about the first generation cars and some said since it's Subaru it should be fine... right.
our engines were a combination of two technologies Toyota+Subaru so something was bound to show up :/ sucks that we were the ones affected
The Following User Says Thank You to gdi2290 For This Useful Post:
StarsGarrador (08-30-2012)
Old 08-29-2012, 12:17 AM   #37
wheelhaus
wheelhaus's Avatar
Look at it this way, this doesn't necessarily point to a bad design, just bad parts. A bad design would result in every car being affected. Recalls/TSBs can affect any number of cars or other products, even those that have been in production for years. Stay optimistic!
wheelhaus is offline   Reply With Quote
Old 08-29-2012, 01:33 AM   #38
avholic
avholic's Avatar
Drives: BRZ WRBL6MT
Originally Posted by serith View Post
... and that there isn't even a bulletin or recall yet for this issue?
It's Subaru Service Bulletin 02-132-12. I got it off this forum and saved it on my smartphone just in case.
Google "tsb 02-132-12" and it leads right back to ft86club.com and to techinfo.subaru.com/static/whatsNew.html with link to PDF (if you have access to their site):
02-132-12 - Technical Service Bulletin - DTCs Relating to the AVCS (Active Valve Control System) - Aug 21, 2012 - [View PDF]
avholic is offline   Reply With Quote
The Following User Says Thank You to avholic For This Useful Post:
gdi2290 (08-29-2012)
Old 08-29-2012, 04:55 AM   #39
gdi2290
gdi2290's Avatar
wow that sucks for that guy he had to claim his car a lemon I don't blame him for moving to a 370z with all problems he has had :/
Old 08-29-2012, 09:44 PM   #40
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
False, not all....mine is at 4,000+ miles, no CEL...Dave-ROR's is at 8,000+ miles no CEL...matter of fact we've haven't had 1 BRZ or Impreza in for this concern...and we sell quite a few...
And it's not a top engine rebuild, it involves the Oil Control Valves (for the VVT), the Exhaust Cam Sprocket and the ECM. In some cases just the OCV's need to be replaced, in others only the Cam sprockets, and in a few, all of the parts need to be replaced.
It can affect Impreza's with the FB20 and all models with the FA20.
The TSB only applies if you have had a CEL.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-29-2012, 09:49 PM   #41
Hotlava86
Hotlava86's Avatar
The question was "could it happen to an AUTOMATIC as well." and i responded saying that it could happen to any regardless of transmission. and i have 6 people locally that had to have valves, cam shafts, sprockets, a timing actuator. so YES it can happen to ALL FRS/BRZ regardless of transmission. That is what was being said.
Old 08-29-2012, 10:38 PM   #42
Opie
Opie's Avatar
Sorry, your post read like "all" will do this...not that "all" could do this..
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 04:26 PM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
