Old 06-09-2023, 07:28 PM   #29
spike021
spike021's Avatar
Someday I'll crack open my original transmission to shim the input shaft bearing like we discussed. Will be interesting. Both of my transmissions are super picky about downshifting into first.
3/4 rod overtravel? Sounds like I need some schoolin'
I've never been able to get my transmission to downshift into first really, except _maybe_ from 3-4mph, like right around where the car would lug in 2nd if I let it.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 2 Users Say Thank You to spike021 For This Useful Post:
Dzmitry (06-13-2023), Ultramaroon (06-10-2023)
Old 06-09-2023, 08:49 PM   #30
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
It's super weird that there's apparently such a wide variation, and so common. I'm also glad mine don't have that issue, lol.
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
The Following 2 Users Say Thank You to RACECAR go brrr! For This Useful Post:
soundman98 (06-10-2023), spike021 (06-10-2023)
Old 06-09-2023, 09:37 PM   #31
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I saw this and all those, "what is this ball stuck to my drain plug?" threads made more sense.
https://www.jackstransmissions.com/t...ervice-brz-frs
When the 3-4 Shift Fork / Gear Slider overextends on the gear hub, there is a chance that the small synchro spring and detent ball can pop out, causing additional issues. We correct this issue by replacing the gear hub detents with a much more robust style. We also install heavy duty bronze rail bushings to keep the shift rails from wobbling around inside the transmission. This results in more precise shifting.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 06-10-2023, 12:57 AM   #32
Ultramaroon
not playing cards
Ultramaroon's Avatar
Aha! Gotcha. Thanks!
Old 06-10-2023, 01:02 AM   #33
Ultramaroon
not playing cards
It's not a bug. It's a feature.
Perfectly normal. Keeps less attentive drivers from money-shifting into first and potentially wiping out.
edit: To clear up any doubt, here's a page from the service manual with the relevant IPB. Scroll to the bottom. It's called the "1st shift restrict ball."
Old 06-10-2023, 10:22 AM   #34
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The location of that ball reinforces the importance of the oil.
On this transmission the 1/2 shift hub is on the layshaft, submerged when the car is parked, and very likely soaking wet with it's toes in the oil bath even when running and flinging oil around the case. If you've that OEM fill GL-3 goop in there that's a lot of jelly that little ball, and that shift ring and synchros have to push out, and a lot of warming up to do before it gets as smooth as a more high tech oil.
The Following 3 Users Say Thank You to RZNT4R For This Useful Post:
blsfrs (06-10-2023), NoHaveMSG (06-10-2023), Ultramaroon (06-10-2023)
Old 06-10-2023, 07:17 PM   #35
Ultramaroon
not playing cards
Not specifically that ball, but yes. It's also the reason timing is especially critical for the cold 1-2 shift. That jelly quickly drags down the speed of the whole gear set anytime the trans is in neutral with the clutch disengaged.
Pro tip; shift with a quick gentle open-fingered flick from first to second without pausing in neutral. With good technique, even stone cold, it just falls into gear.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
Dzmitry (06-13-2023), humfrz (06-10-2023), NoHaveMSG (06-11-2023), soundman98 (06-10-2023), spike021 (06-11-2023)
Old 06-10-2023, 09:55 PM   #36
humfrz
Also, with better technique, you don't even have to use the clutch -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Dzmitry (06-13-2023), spike021 (06-11-2023), Tokay444 (06-10-2023), Ultramaroon (06-11-2023)
Old 06-11-2023, 12:13 AM   #37
soundman98
ProCrastinationConsultant
soundman98's Avatar
Hmm. Well here's a video I made many years ago after getting into an argument with someone on Facebook about it, lol. I downshift into 1st at 15 and 20 both without double clutching. I'll also note I had to have a new transmission installed at 40k (because my 5th gear synchro went wonky) and that transmission also doesn't require double clutching. So I'm 2 for 2 on the "defective" 1st gear lockout if that's the case.
i've got a weird theory that either my clutch drags slightly, or i unintentionally drag the clutch.
my car definitely has a 1st gear lockout, as it won't fall in unless the revs are first matched or over-reved before the shift. but i've never double clutched.
normally when i'm going 2-1 at anything other than a stop sign, it's at the upper limit of 1st, and i intend to rotate the rear around the corner(not always sideways, or skidding, many times just enough to roll the tires over).
it's almost automatic at this point, but i'll rev-match 4-3-2, line up for the corner, then clutch-in, drop out of 2nd, rev up while holding towards 1st until it drops in, and then release the clutch(not pop) as it's falling into 1st...
both of my early '14's operated the same.
though as long as i'm under-reved for 1st, it will refuse to go in.
i do wonder if it's my/your technique that's working around the mechanical 1st gear lockout, or there's enough clutch dragging to keep the input shaft spinning to follow the rpm jump.
personal technique would make more sense, as we're both a sample size of 2 different transmissions operating the same way, and the odds of mass manufacturing skew against us.
of note, i never down shift for the first mile-ish of use, the fluid is too cold, and nothing wants to work.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (06-11-2023), Ultramaroon (06-11-2023)
Old 06-11-2023, 01:51 AM   #38
Ultramaroon
not playing cards
Even with the clutch fully disengaged, there's always a tiny bit of contact somewhere on the friction disc. Maybe even windmilling. It wasn't until getting into a discussion with another forum member here that I ever tried just revving up in neutral with the clutch disengaged. It actually works when warm. There isn't enough contact to overcome the viscous drag of cold lube. If it did, I would suspect something was not quite kosher with the clutch.
I've driven a couple which were super easy to downshift into first, even without doing anything special to spin up the input side.
humfrz (06-11-2023), soundman98 (06-11-2023)
Old 06-11-2023, 02:59 AM   #39
humfrz
Yep, in my NC Miata, I could shift into first gear at 40 MPH. The thing was that you could only let the clutch out once per car -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Dzmitry (06-13-2023), soundman98 (06-11-2023), Ultramaroon (06-11-2023)
Old 06-11-2023, 04:02 AM   #40
Ultramaroon
not playing cards
lol
humfrz (06-11-2023)
Old 06-21-2023, 01:57 AM   #41
redvee86
redvee
Drives: 2012 Sonic Blue 86 GTS AT
I find that if I get the revs up to just over 4k after a cold start and shift 1st to 2nd it is a smooth shift. Generally lower rpms will make a crunching noise.
The difficulty shifting 3rd to 2nd after cold start is frustrating!
redvee86 is offline   Reply With Quote
Old 06-21-2023, 01:59 AM   #42
redvee86
redvee
So is there a consensus on the best oil to use for the transmission?
Do I need to be extra careful when shifting 1-2 in cold? lapsio BRZ First-Gen (2012+) — General Topics 49 11-22-2021 11:27 AM
2018 cold shifting konahic BRZ First-Gen (2012+) — General Topics 29 02-28-2020 06:09 PM
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 04:48 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 05:24 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
