#29 | |
ProCrastinationConsultant
that thin oil still concerns me...
#30 |
Still leaves a film. The engine is designed to tolerate it.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soundman98 (09-08-2022), Ultramaroon (09-08-2022) |
#31 |
Drives: 2013 FR-S, 2017 BRZ
Peanut gallery thought.. what about priming the system by pouring oil into the galley at the top of the block or thru the oil filter holes?
There's a farking yuge port on top of the block by the AC compressor- (16 or 18mm thread I forget now). You could easily stick a funnel on that thing and fill the engine with oil instead of the filler cap on the valve cover. That's basically how you prime an old school water well pump-- pour a few gallons of water into the output end until there's a head built up, then fire up the pump and voila. BUT.. that might also present the air evac problems mentioned before.. just thinking out loud. When I put my last engine in, I certainly crossed my fingers, said a couple Hail Marys, and then counted Mississippis when I hit the ignition. the thing fired up for 1-2 seconds, clattered real bad, and shut off. I thought I broke something on the cam gears, then realized there was air in the fuel lines to be purged. I cranked it again and after a few seconds it fired up and clattered until the cam thingies built oil pressure and it all ran smooth like buttah. Plug and pray! |
| The Following User Says Thank You to Matt93SE For This Useful Post: | Ultramaroon (09-08-2022) |
#32 |
not playing cards
There are, for the sake of definition, several modes of lubrication. In this case we are concerned with the transition from thin film to hydrodynamic. We depend on thin film lubrication with every cold start. If the film stayed cool, we wouldn't even need the oil pump.
Stirring any fluid raises its temp. Viscosity drops as temp increases. (I know - duh) We're safe as long as the lubrication mode switches to hydrodynamic before the film gets too hot. That's it in a nutshell.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#33 | |
Priming is really done once the oil gets sucked into the pump and that first bit gets squeezed by the pump. After that point, the engine passages fill rapidly. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | soundman98 (09-08-2022) |
#34 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I believe we sometimes overthink these things. I am certain I do.
Slow is smooth, and smooth is fast
#35 |
not playing cards
Are you sure about that?
| The Following 6 Users Say Thank You to Ultramaroon For This Useful Post: | Capt Spaulding (09-11-2022), Jdmjunkie (09-10-2022), NoHaveMSG (09-10-2022), soundman98 (09-10-2022), Spuds (09-12-2022), Tcoat (09-11-2022) |
#36 |
Persona Non Grata
| The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post: |
#37 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | DarkPira7e (09-12-2022), soundman98 (09-12-2022) |
#38 | |
There are no instructions anyplace other than YouTube "experts" that say you should prefill the filter. Even the filter does not say to prefill the filter!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#39 |
Rust bucket enthusiast
It's like they think the manufacturer doesn't want the car to have as much reliability as possible. Some of the nonsense invented by enthusiasm is just...well, their heart is in the right place. Sometimes the best thing you can do is follow directions though.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Ultramaroon (09-12-2022) |
#40 |
not playing cards
Step-2 clearly shows the filter being filled with oil.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (09-12-2022) |
#41 |
Drives: Crapcan
Are you sure? It looks like they are lubing the forming die after cleaning.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#42 |
not playing cards
Dammit! I don't know. Maybe there's a youtube video that can help.
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
| Tags |
| method, oil, oil prime, prime |
| Priming the oil filter | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 08-19-2014 06:04 PM |
| Borla "full system" VS "full system" minus headers | Trashed675 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 01-07-2014 01:17 AM |
| Be Spoke system/ BRZ system navigation swap | Mrqb22 | Electronics | Audio | NAV | Infotainment | 4 | 09-27-2012 06:48 PM |
