Old 09-07-2022, 10:06 PM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
Meh. There is enough residual sitting on all the oiled parts to last that few seconds.
I have pulled apart engines that have sat in a field for a decade or more that still had residual oil on everything critical.
of note though, all those motors didn't use the 0-20 mix.
that thin oil still concerns me...
Old 09-08-2022, 09:04 AM   #30
Still leaves a film. The engine is designed to tolerate it.
soundman98 (09-08-2022), Ultramaroon (09-08-2022)
Old 09-08-2022, 01:54 PM   #31
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Peanut gallery thought.. what about priming the system by pouring oil into the galley at the top of the block or thru the oil filter holes?
There's a farking yuge port on top of the block by the AC compressor- (16 or 18mm thread I forget now). You could easily stick a funnel on that thing and fill the engine with oil instead of the filler cap on the valve cover.
That's basically how you prime an old school water well pump-- pour a few gallons of water into the output end until there's a head built up, then fire up the pump and voila.
BUT.. that might also present the air evac problems mentioned before.. just thinking out loud.
When I put my last engine in, I certainly crossed my fingers, said a couple Hail Marys, and then counted Mississippis when I hit the ignition. the thing fired up for 1-2 seconds, clattered real bad, and shut off. I thought I broke something on the cam gears, then realized there was air in the fuel lines to be purged.
I cranked it again and after a few seconds it fired up and clattered until the cam thingies built oil pressure and it all ran smooth like buttah.
Plug and pray!
Matt93SE is offline   Reply With Quote
The Following User Says Thank You to Matt93SE For This Useful Post:
Old 09-08-2022, 03:05 PM   #32
There are, for the sake of definition, several modes of lubrication. In this case we are concerned with the transition from thin film to hydrodynamic. We depend on thin film lubrication with every cold start. If the film stayed cool, we wouldn't even need the oil pump.
Stirring any fluid raises its temp. Viscosity drops as temp increases. (I know - duh) We're safe as long as the lubrication mode switches to hydrodynamic before the film gets too hot. That's it in a nutshell.
soundman98 (09-08-2022), Spuds (09-12-2022), Tcoat (09-08-2022)
Old 09-08-2022, 03:55 PM   #33
KillerBMotorsport
KillerBMotorsport's Avatar
Same premise as to why you don't want to fill a filter with oil beforehand. Anything that makes it harder for the pump to move the air out of the system and replace it with oil, is going to increase the time it takes to prime.
Priming is really done once the oil gets sucked into the pump and that first bit gets squeezed by the pump. After that point, the engine passages fill rapidly.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Old 09-10-2022, 02:51 PM   #34
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I believe we sometimes overthink these things. I am certain I do.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post:
humfrz (09-11-2022), NoHaveMSG (09-10-2022), Spuds (09-12-2022), Tcoat (09-10-2022)
Old 09-10-2022, 05:22 PM   #35
Are you sure about that?
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
Capt Spaulding (09-11-2022), Jdmjunkie (09-10-2022), NoHaveMSG (09-10-2022), soundman98 (09-10-2022), Spuds (09-12-2022), Tcoat (09-11-2022)
Old 09-11-2022, 01:12 PM   #36
Capt Spaulding
Persona Non Grata
NoHaveMSG (09-11-2022), soundman98 (09-11-2022), Tcoat (09-11-2022), Ultramaroon (09-11-2022)
Old 09-11-2022, 09:08 PM   #37
You may want to think about -
DarkPira7e (09-12-2022), soundman98 (09-11-2022)
Old 09-12-2022, 10:10 AM   #38
THIS ^
There are no instructions anyplace other than YouTube "experts" that say you should prefill the filter.
Even the filter does not say to prefill the filter!
Clipdat (09-15-2022), DarkPira7e (09-12-2022), x808drifter (09-13-2022)
Old 09-12-2022, 10:49 AM   #39
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
THIS ^
It's like they think the manufacturer doesn't want the car to have as much reliability as possible. Some of the nonsense invented by enthusiasm is just...well, their heart is in the right place. Sometimes the best thing you can do is follow directions though.
Ultramaroon (09-12-2022)
Old 09-12-2022, 12:19 PM   #40
Step-2 clearly shows the filter being filled with oil.
Spuds (09-12-2022)
Old 09-12-2022, 12:25 PM   #41
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you sure? It looks like they are lubing the forming die after cleaning.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-12-2022), Spuds (09-12-2022), Ultramaroon (09-12-2022)
Old 09-12-2022, 12:56 PM   #42
Dammit! I don't know. Maybe there's a youtube video that can help.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
NoHaveMSG (09-12-2022), soundman98 (09-12-2022), Spuds (09-12-2022), x808drifter (09-13-2022)
method, oil, oil prime, prime
Priming the oil filter radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-19-2014 05:04 PM
Borla "full system" VS "full system" minus headers Trashed675 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 01-07-2014 12:17 AM
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 05:48 PM
