Old 06-26-2023, 11:00 PM   #29
alphasaur
friendly
Drives: 17' 86
Originally Posted by AussieBRZ View Post
Yes seems strange usually di fuel pressure failry steady 3 to 4 MPa at idle
Check the grounds on the DI computer under Bonnett all three bolts in and tight
Also it might be the di fuel pressure sensor feeding the di computer weird info then the di pump tries to follow that.
My guess would be di pump or di pressure sensor if the di computer is correctly earthed/grounded unless there is something very weird in tune
going to look into this, thank you!
Super appreciate you!
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-27-2023, 12:26 PM   #30
alphasaur
friendly
Drives: 17' 86
the bottom bolt on the injector ecu was loose! But it didn't fix the problem
Going to replace the hpfp and see if that fixes it. If not I'll pull the IM again and swap the sensor.
Tuner seems dismissive of the issue and I feel like my fuel trims are high and afr seems inconsistent at idle and cruising IDK
The Following User Says Thank You to alphasaur For This Useful Post:
AussieBRZ (06-27-2023)
Old 06-27-2023, 06:22 PM   #31
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Check the bracket bolts on di computer as well see photo
AussieBRZ is offline   Reply With Quote
The Following User Says Thank You to AussieBRZ For This Useful Post:
alphasaur (06-27-2023)
Old 06-27-2023, 09:25 PM   #32
alphasaur
friendly
Drives: 17' 86
remounted the injector computer and checked those bolts, super snug.
Start car up and fuel status stays in mode 2, once it drops to idle it does the fluctuating between 2 and 4 and the ticking starts
Is it possible I boinked a wire when I moved the injector computer to remove manifold?
When I go to check ready states fuel sytem is unready which I find odd so I don't think it will throw a code?
Could it be my e85 flex fuel kit still being installed?
Old 06-28-2023, 06:09 PM   #33
tomm.brz
Drives: brz 2017 hksv2
which map sensor?
. if you have a 4bar map... change it.
Old 06-28-2023, 06:30 PM   #34
Ultramaroon
not playing cards
Ultramaroon's Avatar
Not sure where this is going so I'll just throw this out there.
It runs well enough to go closed-loop mode while idling. The trouble starts when it tries to switch over to DI. That is something the ECU does to minimize emissions while idling. It goes into a lean-running mode with only the DI enabled.
I wonder if it can't switch to DI simply because the DI rail pressure is not being regulated. That sawtooth pattern seems to me like it's hunting because of inability to control. Since pressure reading is there and seems reasonable, I'd go back to suspecting the spill control valve, or the actuation signal.
Again... I've no firsthand experience with this. I'm just thinking out loud about how I would approach the issue.
Old 06-28-2023, 11:15 PM   #35
alphasaur
friendly
Drives: 17' 86
Originally Posted by tomm.brz View Post
which map sensor?
3 bar omni sensor
I get new pump in next week I think, so can try that.
What is odd is that when driving around it seems to hit requested values, it just seems to be all over the place idling.
Old 06-30-2023, 03:02 PM   #36
alphasaur
friendly
Drives: 17' 86
So someone VERY nice sent me a base map and the issue is resolved. At idle there is no more clicking, fuel pressure seems to hover around ~4 and fuel system status is steady at 2.
I am pretty irritated with my tuner, they totally just ignored my concerns.
I spent $500 on a HPFP and pressure sensor along with new gaskets in case I had a leak.
What should I do?
Not sure I want them touching the tune on my car anymore. Can't imagine the conversation of "hey your tune you said was fine was messing up my car and a free tune from a nice man fixed my issue" is going to go over well.
Honestly would like a partial/full refund and to go somewhere else
any guidance?
Wally86 (07-03-2023)
Old 06-30-2023, 03:33 PM   #37
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I am super irritated with my tuner.
They totally just ignored my concerns.
What should I do?
any guidance?
The tuner is going to keep making these mistakes if nobody tells them! Best to approach it neutrally and respectfully ask if there's a way to recoup some of the costs because of their negligence.
Super awesome that it was tune related! I wonder what parameters were at fault...
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (06-30-2023), Wally86 (07-03-2023)
Old 06-30-2023, 03:40 PM   #38
alphasaur
friendly
Drives: 17' 86
I will try to find out what parameters were at fault. The tune from tuner 1 (who I paid) is locked.
I just emailed them letting them know the issue appears to be resolved with a basemap from someone else. Will update as I get more info.
DarkPira7e (06-30-2023)
Old 06-30-2023, 03:47 PM   #39
DarkPira7e
DarkPira7e's Avatar
I know it sounds crazy, but were it me, I'd try reflashing the old map just to see if the issue returns and that it wasn't some bug with that individual flash instance. I've seen stranger things. Worst that happens is the issue is back and you flash the base map back on, just will cost you 5-10 minutes. Up to you though
Old 06-30-2023, 03:48 PM   #40
alphasaur
friendly
Drives: 17' 86
ooo will try it to rule that out.
I had a super pleasant experience with them with my flextune sadly this experience isn't going as well.
Old 06-30-2023, 08:18 PM   #41
tomm.brz
very probable the bug will return
probably just a racerom bug, they are very present specially in US tunes
go to tuner number 2 : )
The Following User Says Thank You to tomm.brz For This Useful Post:
alphasaur (07-01-2023)
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
Full blown Stage 1 premium turbo kit vs JDL v2.1 Greenbean Forced Induction 11 09-05-2019 05:10 PM
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 03:38 AM
Help full blown stage 1 turbo h22mike Engine, Exhaust, Transmission 40 12-08-2014 12:31 AM
Full Blown, stage 2 turbo kit Ironsquid User/Vendor/Sponsor Reviews, Feedback, Comments 4 02-18-2014 12:22 AM
