#29 |
Drives: 2013 frs
Oh and it seems to have a stock tune. At least that is what I can tell through techstream. I would reflash it myself but I don't have the mongoose cable. Just one of the amazon mini vci's. ZA1J700C is what it says it has. I have tried to reflash with the cable I have and it says it failed to read calibration. Could it be locked by a tuner?
#30 |
Drives: 2013 frs
Changed all fuel injectors too and made sure all the numbers matched on the port and direct both
#31 |
Drives: 2013 frs
When replacing the engine we put a thin layer of antiseize between the engine and transmission. Would that cause a grounding issue? May have to end up showing or telling the dealer how to force ecu into programming mode.
#32 | |
Drives: WRB BRZ
You cannot do it with vci cable and the pirate techstream |
#33 | |
Drives: WRB BRZ
I've swapped lots of ECU between cars, reflashed no issues with cams, it's a learner setting. But very occasionally a ECU has a actual hardware problem Does techstream show and error codes from any module in car is engine, transmission , vsc stability abs, dash cluster ? |
#34 | |
Drives: 2017 BRZ w/PP
There should be a grounding strap that connects them on the top. |
| 2017 fa20 engine into 2013 car? | ROADRACER | Engine, Exhaust, Transmission | 91 | 12-29-2021 12:52 AM |
| FS: Engine- 2015 BRZ FA20 56k miles | FT86Logic | Engine, Exhaust, Bolt-Ons | 1 | 08-10-2018 08:07 AM |
| FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 07:39 PM |
| FA20 Engine Wins Ward's 10 Best Engines of 2013 | Jeffsu350 | Scion FR-S / Toyota 86 GT86 General Forum | 111 | 03-15-2015 04:39 AM |
