Old 08-16-2022, 07:12 AM   #29
Robbie7c
Drives: 2013 Subaru BRZ
Originally Posted by RZNT4R View Post
Have you even had the alignment checked?
I haven’t, but thats a good idea, I’ll get that checked
Robbie7c is offline   Reply With Quote
Old 07-20-2023, 12:59 PM   #30
Robbie7c
Ok it's been a while, I've gotten a bit distracted and put this issue on the backburner, had other things to focus on. But I do have some updates to hopefully help narrow down the issue.
So I put a new clutch in the car, got brand new tires, and a 4 wheel alignment. Alignment shop told me I had play in the rear pillow ball bushing so had that replaced as well.
The issue still persists. I can definitely say it only happens around left hand corners, right hand corners are smooth as butter. The traction problem I mentioned earlier where the rear end would step out around higher speed corners is completely gone, likely fixed from new tires or the pillow ball bushing.
So it's got to be either the rear right shock or the diff I would think? I can't imagine it's driveline play cause I would think if it were that I would have a problem around both right and left corners.
reason I think it could be the diff is maybe just the way it locks up is only effected around left hand corners. Not an expert on these diffs maybe some one could shed some light on that.
Clunking on hard cornering from front suspension Open Loop Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-01-2017 09:47 AM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 09:40 AM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 02:04 PM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 01:49 PM
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 09:06 AM
