Old 12-19-2022, 12:30 PM   #29
Jynx
Drives: 2013 Subaru BRZ
Code p0441
well if anyone is still following this, P0441 is a bullshit code and it was actually the leak detection pump valve assembly. has nothing to do with the purge valve, lines, or gas cap. The whole rear subframe is being dropped tomorrow to even get to it. price to fix is about 1300.
Jynx is offline   Reply With Quote
The Following User Says Thank You to Jynx For This Useful Post:
blsfrs (12-19-2022)
Old 12-19-2022, 04:52 PM   #30
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What exactly is being repaired/replaced?
Old 12-19-2022, 05:47 PM   #31
Jynx
Leak detection pump valve assembly. also referred to as the canister pump module. it is located right next to the charcoal canister.
blsfrs (12-20-2022)
Old 12-20-2022, 02:45 PM   #32
It has everything to do with the purge valve, lines and cap! It is the device that makes sure all those things are working right and an integral part of the system.
Old 12-20-2022, 03:04 PM   #33
Jynx
wrong. wasn't the purge valve. everyone tried to tell me it was the one under the intake. the one in the back is not a "purge valve"
Old 12-20-2022, 03:29 PM   #34
Doesn't change that the test pump is a part of the whole system no matter where the purge valve is located.
Old 12-20-2022, 03:45 PM   #35
Ultramaroon
not playing cards
Ultramaroon's Avatar
"Everyone..." You didn't look at the service manual at all, did you?
Old 12-20-2022, 03:46 PM   #36
Jynx
oh i did for 3 days straight. fought 3 dealerships on it and one was finally smart enough. only took a year.
Ultramaroon (12-20-2022)
Old 12-20-2022, 04:10 PM   #37
Ultramaroon
not playing cards
lol... that SUCKS!
Old 12-20-2022, 06:32 PM   #38
Jynx
at the moment the car is looking good but they are gonna keep testing it to make sure that this is actually it.
Old 12-21-2022, 05:38 PM   #39
Jynx
haha sike, that did not fix it.
Old 12-22-2022, 12:11 PM   #40
blsfrs
blsfrs's Avatar
Did they replace everything? Pump, module, canister? While it was disassembled, did they smoke or pressure test all of the lines?
Old 12-22-2022, 12:18 PM   #41
Jynx
yes they did everything u just stated lol. now we are thinking a PCM issue because the PCM isnt even controlling the valve in the front and is only partially giving a signal to the one in the back. it just became a lot more money lmao
The Following 3 Users Say Thank You to Jynx For This Useful Post:
blsfrs (12-22-2022), Ultramaroon (12-22-2022), x808drifter (12-23-2022)
Old 01-03-2023, 07:59 PM   #42
Jynx
Update ~
ECU is getting checked tomorrow and may have to go the dealership to get completely replaced and reprogrammed. (if anyone is still following.)
blsfrs (01-04-2023), Ultramaroon (01-04-2023), x808drifter (01-09-2023)
Help diagnosing P0441 code 1Saucyyy_brz Issues | Warranty | Recalls / TSB 3 09-18-2022 06:45 PM
Engine code p0171 and p0441 frscory Issues | Warranty | Recalls / TSB 6 02-20-2022 07:06 PM
Having trouble with code p0441 Jynx Issues | Warranty | Recalls / TSB 5 02-19-2022 06:17 PM
p0441 cel code bryan.catano93 Engine, Exhaust, Transmission 5 03-12-2018 12:38 PM
Check engine code P0441 Gibson Engine, Exhaust, Transmission 0 11-23-2016 06:39 PM
