#29 |
Drives: Subaru BRZ
I am in all-off mode, guess did not figure out how to switch to displaying degrees.
Edit: looks like degree display is available only on the 86. |
#30 | |
Drives: 22 BRZ limited
#31 | |
Drives: 2022 GR86
Follow the build thread for my GR86!
#32 |
Drives: 2022 GR86 Premium Track bRed
rouuuuuugh... the horizontal bar graphic is terrible, way too wide a range, and really unclear what the temps actually are. the android auto solution looks like a good workaround though! You could get a cheap burner phone just for track days if you're an apple guy |
#33 |
Drives: '23 BRZ Limited
That seems so incredibly dumb.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#34 |
Drives: Subaru BRZ
More post hpde findings: The front driver tire rubbed on the wheel liner. I had a passenger for 3 sessions but there is no rubbing on the passenger side. Raised the car all around, driver side: 3 turns front, 4 turns rear, passenger side: 2 turns front, 3 turns rear. Fixed the wheel liner with Gorilla tape and we will see next time if the rubbing is still there.
#35 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#36 |
Drives: Subaru BRZ
Could not resist and added the AP Racing CP9451 Radi-CAL rear BBK....
#37 |
Drives: Subaru BRZ
Also, installed the Karcepts FSB, just need to adjust the endlinks and should be ready to go.
| The Following User Says Thank You to Code Monkey For This Useful Post: | villainous_frx (06-22-2022) |
#38 |
Drives: Subaru BRZ
After raising the car a bit, figured it would be good to have another alignment. Used this opportunity to move over the REAL leather steering wheel as well.
#39 | ||
Love the updates, keep up the good work! |
| The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | Code Monkey (07-11-2022), villainous_frx (07-09-2022) |
#40 |
Wes
Bit off topic but I saw you had the KDT924 installed on the previous build. How did you like it? I had the diff inserts but had to take them off unfortunately as they were making my 1 piece driveshaft vibrate. Apart from the bushing failing (on track I presume) how was the NVH? Livable? Thanks!
Instagram: @gt86ws
#41 |
Drives: Subaru BRZ
NVH was livable, but obviously I would not recommend these bushings...
#42 |
Wes
I'll reach out to them, show them the pic and see what they say.
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Code Monkey (07-19-2022) |
| 2017 Subaru BRZ hpde build | Code Monkey | Member's Car Journals | 207 | 04-18-2022 11:11 AM |
| 2022 BRZ JDM Spec build at HKS USA for SEMA2021 | 143 | BRZ Second-Gen (2022+) — General Topics | 5 | 02-14-2022 01:27 PM |
| redSerpente’s HPDE/86CUP Street build | redSerpente | Member's Car Journals | 10 | 04-26-2021 07:50 PM |
| LS3 HPDE / Time Attack Build | RavioliG | Member's Car Journals | 17 | 02-11-2018 04:56 PM |
| 86_Freak - Build for DD/C Street/HPDE duties | 86_Freak | Member's Car Journals | 3 | 03-07-2016 10:15 AM |
