Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-10-2021, 07:36 PM   #29
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Damn.. I was hoping to be able to run some 18x9.5 +38 with this new gen but guess not
Figure 255's won't fit with it so hoping i can fit a 245/35 then
I don't mind rolling the fenders if it means i can squeeze 255 though, maybe i'll add a tiny bit of camber to make it fit
suhhh is offline   Reply With Quote
Old 11-11-2021, 01:38 AM   #30
ForeverCar
Drives: 2022 BRZ and some other cars
I have a set of 17x9 ET42 that I plan on running on my incoming BRZ with 245/40/17. I’ll share more once I put them on.
ForeverCar is offline   Reply With Quote
The Following 2 Users Say Thank You to ForeverCar For This Useful Post:
Pete (11-11-2021), Yoshoobaroo (11-11-2021)
Old 11-11-2021, 11:12 AM   #31
Derka
Drives: 2015 frs
I have some weak boi specs on order. Went with 18x8.5 +44 plan on running a 235/40 for a oem+ setup
Derka is offline   Reply With Quote
Old 11-11-2021, 11:48 AM   #32
grst1
grst1's Avatar
Drives: '94 Ford Aspire
I have a set of RPFs 17x9 +45 with Conti ExtremeContactForce 245/40/17 I will try on once I have my car and report back.
grst1 is offline   Reply With Quote
The Following 2 Users Say Thank You to grst1 For This Useful Post:
Frost (11-11-2021), Pete (11-11-2021)
Old 11-11-2021, 02:35 PM   #33
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Been following this topic with amusement; I've been OK with OEM sizes on cars for a while, (sticky + light) > fat for me. YMMV, of course.
You have not suffered until you've taken delivery of a new car fitted with 155/80-13 tires; yesterday, I replaced a tire on a hand truck almost that wide!
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
The Following User Says Thank You to tiger1964 For This Useful Post:
bcj (11-12-2021)
Old 11-11-2021, 03:12 PM   #34
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
My 245/40-17 on 9" wedsports are lighter than 215/45-17 on oem 7.5".
dragoontwo is offline   Reply With Quote
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
Jucostud (11-11-2021), MotoX16 (11-23-2021)
Old 11-11-2021, 03:45 PM   #35
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by timurrrr View Post
Could be that Subaru engineers saw your posts about reverse stagger and thought it was a good idea!
Lol. Probably just a young engineering team.
Old 11-12-2021, 09:18 AM   #36
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
Thanks for sharing that. This suggests good opportunities, with the right wheels & tires, to reduce unstrung weight if running more modest -- perhaps even OEM -- wheel/tire sizes.
Old 11-12-2021, 10:46 AM   #37
ZDan
ZDan's Avatar
Drives: '23 BRZ
Can you take a photo of the fitment from above the wheel, and slightly inboard?
Before I dialed in -2.5º of camber, I could find a spot where the top of the wheel would fully cover the bottom of the wheel, but was still visible from under the fender.
Here ya go, pics from above with 245/40-17 on 17x9 +35 wheels, car lowered to just under 13" from hub to fender, -3.2 front -2.7 rear camber.
NOTE: This is a 2017 car, not a '22!
The Following 3 Users Say Thank You to ZDan For This Useful Post:
DocWalt (11-12-2021), Pete (11-12-2021), timurrrr (11-12-2021)
Old 11-12-2021, 11:10 AM   #38
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
So, there's a little bump out in the fender liner just inside of the fender lip that is what the tire has been hitting. I'll try to take pics later today, but I think the "less rubbing" has been a self clearancing thing lol. +35's with 245's might actually work. I'm tempted to try it with another set of Enkeis and some 245/40/17 PS4S's for tooling around in the winter here and back up heavy rain autocross tires.
trippinbillies40 is offline   Reply With Quote
The Following 5 Users Say Thank You to trippinbillies40 For This Useful Post:
Brock H. (11-15-2021), DocWalt (11-12-2021), Jucostud (11-12-2021), timurrrr (11-12-2021), ZDan (11-12-2021)
Old 11-12-2021, 02:24 PM   #39
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Are you saying the rubbing has trimmed off that bump?
Have you looked at why that bump is there, what's underneath it?
Is the bump you're talking about located around any of these things?
Source: https://www.instagram.com/p/CU40Tv4pdnK/
Originally Posted by Lightened View Post
timurrrr is offline   Reply With Quote
Old 11-15-2021, 01:01 PM   #40
OkieSnuffBox
Drives: '23 BRZ Limited
Same here. Part of the reason I decided not to put a deposit on one or I'd already have it. Wanted to wait a bit for the aftermarket to figure out wheel fitments, suspension, exhausts, tunes, etc.
But as mentioned, when you buy high quality light wheels, you can wider, lighter, with wider sticky tires and STILL be lighter than the OEM setup. I'll likely end up TWS wheels.
Old 11-15-2021, 03:31 PM   #41
skkk
Drives: 2022 BRZ Sport-Tech
Thinking to put 57DR 17x9 +38 with 245/40/17 AD08R from my first gen to the second gen.
Ordered HKS Hypermax IV SP and will pair with RLCA.
Car is arriving in Feb/March and will test it out once it's arrived.
skkk is offline   Reply With Quote
Old 11-15-2021, 03:52 PM   #42
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
Originally Posted by ZDan View Post
Not if lowered sufficiently...
245/40-17 on 17x9 +35, just under 13" hub to fender lip all 4 corners, stock control arms, camber plates, -3.25 front -2.7 rear camber.
I had these wheels on my 2017 as well, with RCE yellows being my only suspension mod. Beautiful wheels, but the fronts always looked a little tractor-like to me. Wondering if your setup avoided that by going lower?
I plan to try them out on my 2022, but it isn't due until February.
slipstream8 is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 11:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 07:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 08:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 05:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 04:34 PM
