Old 10-14-2021, 09:08 AM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think it is a combination of both issues overloading the fronts more easily. I have watched video from the same track of an S2K with similar mods to me and my car will not turn in the way that car does. Not even close.
My strut-suspended 240Z (with some camber and with from-the-factory rear toe-in fixed!) easily turned in better than my S2000! They had the same weight distribution at 49F/51R with driver and fuel. FT86 suffers because 55F/45R...
Old 10-14-2021, 11:29 AM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by EAGLE5 View Post
I wouldn't argue that the S2K is not superior. It probably is in most ways on the track.
If you had mid corner understeer, maybe Bilstein would tell you to...
Increase rebound rate on front.
Increase compression rate on rear.
Been there, done that. As backwards as it sounds a lot of it was resolved by upping the front sway bar stiffness. It only happens on longer high load corners. In other corners my car is oversteer biased It has been driving me crazy.
Yeah I can imagine that is the primary contributor physics being what it is and all. I should send a link of this guys in car to you cause it is nuts. The fastest twin I know of in the area has aero and 298whp and ran a 1:51.6, this NA S2K makes 210whp on race gas and has aero and ran a 1:49 on A052's and a 1:47.9 on A005's. The corner speeds are absurd
Old 10-14-2021, 12:05 PM   #31
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Did the front pack down mid corner?
Old 10-14-2021, 12:07 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes. Stiffer sway was a band aid. Going to mess with different spring rates next season, on 7kg now. Have another set of 10kg, so need to order 8's and 9's.
Old 10-14-2021, 01:41 PM   #33
strat61caster
strat61caster's Avatar
Being 500# lighter helps too.
ineedyourdiddly
Old 10-14-2021, 05:59 PM   #34
ZDan
ZDan's Avatar
Drives: '23 BRZ
Fer sher! But it's worth noting, the FT86 with driver and fuel puts 10% more load on its front wheels vs. an S2000 with driver+fuel at the same weight. That's significant and I think that's the bigger difference between FT86 and S2000 than front struts vs. double wishbones. That is, assuming the FT86 has crash bolts and/or offset top mounts or camber plates...
If anyone is going down the dirt/rally/rough road type suspension route... grumpysnapper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-01-2021 04:57 PM
Do Rear Suspension Springs Orientation Matter? krayzie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-02-2019 11:01 AM
Tein Type Flex - suspension setting question koevasi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-03-2013 03:20 AM
Lug Nuts, do they matter? jonnyozero3 Tracking / Autocross / HPDE / Drifting 34 04-28-2013 07:48 PM
ARE YOU GONNA BUY IT NO MATTER WHAT serchmarc Scion FR-S / Toyota 86 GT86 General Forum 97 03-19-2011 05:27 PM
