Old 07-15-2021, 11:09 AM   #29
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by steverife View Post
I'm not sure I follow your statement.
Let's consider two extremes.
If a car keeps doing circles around a skidpad, the grip can be optimized by picking some total roll stiffness, and optimizing camber for the amount of roll that given tires generate. Then the relative front/rear roll resistance can be changed to fine tune the balance.
At slalom, the car rolls left to right and back all the time. If transitions take a lot of time, camber changes all over the place. If the suspension settles quickly though, it can provide more consistent grip, and thus better times.
Different race tracks and different AutoX courses fall somewhere in between these two extremes, and possibly benefit from different approaches.
I don't track my car, but a lot of those folks do track their cars and even do time trials with minimal to no changes to set up.
Sure, I also do the same. Doesn't mean that the same setup is necessarily optimal for both applications.
Personally I also use SX2 tires at the track that generate less grip than RE71R's I use for AutoX. I presume the "optimal" amount of total roll stiffness would be different for these different tires, even on the same course.
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
TommyW (07-15-2021)
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 07:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 12:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 03:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
