#29 |
#30 |
Really enjoy my ss1's. If you need camber it's great setup. Tien flex As are good as well
2013 Series 10 FRS #553
#31 |
Drives: 2014 Ultramarine FR-S
I'm surprised nobody has asked this, but what are the exact clicks you have your coilovers set at front & rear? And what tires pressures? From other reviews I've read about the RS-R's, they can be set to ride similar to stock comfort.
| The Following User Says Thank You to NLSP For This Useful Post: | StraightOuttaCanadaEh (06-03-2021) |
#32 |
If you're on a budget, I'd recommend the 17+ struts with RCE Yellow lowering springs. If you you're willing to spend a bit more, the Bilstein B6's with RCE Yellows is a popular pairing as well.
I have the 17+ struts and the Yellows on my 2013 and the the ride quality has definitely improved from stock while dropping it a little bit and giving it a nice look and better turn in. You do lose the adjustability from a coilover but for the money, I think it's a perfect street setup. |
| The Following User Says Thank You to ninzuh For This Useful Post: | Thefalls (06-04-2021) |
#33 | |
#34 | |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Our lower mount is simply built into the cap and has a lockring so it looks similar to the Asian shocks that use an adjustable threaded adapter on a sealed cylinder. The Asian shocks are complete and sealed then they thread a separate mount adapter on the bottom. In their marketing that is a "feature". The Xida cap is not removeable or adjustable. All one piece aluminum race shocks have a cap on the otherwise open cylinder. If the lower cap can actually be removed without opening the shock, it's a two piece shock. If the lower cap seals the cylinder, keeps the oil in and is not adjustable, its a one piece shock. I prefer to call the two piece shocks "length adjustable" and one piece "non-length adjustable". If both types have threaded bodies, they have adjustable preload of course. Last edited by 949 Racing; 06-12-2021 at 11:11 PM. |
| The Following 3 Users Say Thank You to 949 Racing For This Useful Post: |
#35 |
Drives: 2014 BRZ
This is the first I've seen RSR spoken of as low end and uncomfortable...I was actually under the impression they had the reputation of having one of the softer rides due to their rubber inserts? Been trying to decide between Sport-I and the rce ss1...
#36 |
Drives: #337 2017 Toyota 86
RCE SS1 all the way. More travel than RSR, specialized valving and quiet camber plates.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
| The Following 3 Users Say Thank You to Lincoln Logs For This Useful Post: |
#37 |
Drives: 2014 BRZ
| Help needed BC BR Coilovers too bouncy 8k! | CoryeWest | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 10-25-2018 02:18 PM |
| FR-S owner's bumpy ride crushes through the cracks of the streets | SquadRon | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 07-10-2016 07:14 PM |
| FR-S/BRZ Vs. 2015 WRX ride quality | rennlistuser3 | FR-S / BRZ vs.... | 65 | 01-12-2016 12:33 AM |
| Reducing bumpy ride with sportline springs | Lemar58 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-11-2013 10:24 AM |
| How harsh is the ride on 18" vs 17" wheels? | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 07-18-2012 04:08 PM |
