Old 08-05-2020, 07:16 AM   #29
Petah78
Drives: 2022 BRZ sport-tech
Originally Posted by rice_classic View Post
Both are good but the syncromesh from amsoil is full synthetic so when things get hot and fast the oil will prevent the synchro from adequately slowing down the gear and you’ll get a crunch. This is in track/racing scenarios.
I like the 75-110 but I race on the 75-90
Thanks for the reply. The reason why I ask is because I also have a Honda S2000 which i believe to also have a Aisin transmission. I was able to use amsoil syncromesh in that hence I figured I can in the BRZ. From my reading, all syncromesh fluid (5-30) is lighter than 75-90 which is what our transmission specs.
In regards to the diff, why go lighter in track situations where temps are higher?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 08-06-2020, 09:25 AM   #30
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The wear isn’t happening nor do I have a fancy lsd that needs thicker fluid, and thicker fluids can also contribute to higher temps. It wasn’t a ‘solution’ for me. On the advice of csg Mike and allowable by the T4 rules, I just installed the greddy diff cover so I’m looking forward to see how that improves the life of the diff fluid.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
Petah78 (08-10-2020)
Old 08-06-2020, 03:41 PM   #31
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 (75w80, GL-4) in the Gearbox, Motul 300 (75w90) in the diff. NOT LSD oil. There are no clutch discs in there.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 09-07-2020, 02:03 AM   #32
j_ros94
Drives: 2017 Subaru BRZ
Just wanted to ask if the motul 300 is still recommened on a boosted manual brz? Or would you guys recommend something else?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 11-12-2020, 10:15 PM   #33
jflogerzi
jflogerzi's Avatar
Absolutely not in the Diff! Just about any synthetic 75-90 gear oil in the diff. I’m partial to amsoil and motul for Diff
Is this the stuff you use?
https://www.walmart.com/ip/PENNZOIL-...g-FP/744954333
It needs 3qts for transmission and 1qt for the diff right?
2013 Series 10 FRS #553
Old 11-12-2020, 10:41 PM   #34
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Op, what do you do?
If just normal DD, any brand will do.
Old 11-13-2020, 03:06 AM   #35
rice_classic
Thats the stuff!
Its a bit over 2 for the trans but DO NOT use it in the diff! It is NOT for use with hypoid gears like a differential, please use a synthetic gl-5 75w-90 in the diff
SCCA T4 - FRS
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
jeepmor (12-03-2021), jflogerzi (11-13-2020)
Old 11-17-2020, 11:03 PM   #36
jflogerzi
jflogerzi's Avatar
Thats the stuff!
Does the built in spout work or did you need a fluid transfer pump?
Old 11-18-2020, 12:04 AM   #37
rice_classic
For trans I use a funnel and tube, fill from above. Diff, I use a pump.
SCCA T4 - FRS
Old 11-22-2020, 03:53 AM   #38
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
I switched my tranny fluid out with MT-90 and found that it made some things better, and some things worst. On stock fluid, attempting to downshift from 5th to 4th aggressively at 3k+ rmps would lock me out 4th. Other than that, I found the stock fluid to be quite pleasant.
With Redline MT-90, upshifting to 3rd gear would result in a "clanking" sensation and noise, which did happen before, but much more rarely. Going from 1st to 2nd also is a bit more difficult if you shift sloppily, unless you mentally try and slot it in the gear in the perfect angle, then it is very smooth. However, the downshifting lockout issue has been fixed and overall shifts do feel a bit smoother, yet heavier if that makes sense.
I'm curious if others experienced similar results as me and do transmission break down and lose viscosity over time?
Oxyg3n is offline   Reply With Quote
Old 11-22-2020, 12:24 PM   #39
pope
has a funny hat
Drives: 2014 BRZ Limited
I did my trans and diff a couple months ago using the built in spouts by crushing the bottles. A pump would have been easier, but not strictly necessary.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
jflogerzi (11-22-2020)
Old 01-14-2021, 10:19 PM   #40
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Penzoil Synchromax seems to be the leader.
I've used redline MT oil in my 01 Outback 5-speed I bought with 80k on it. It helped with the shifting for sure. 1-2 had a little hitch in it that it eliminated. I never changed it and sold the car at 180k. Thinking back, I'll just go back to Redline. Not sure what flavor of gear oil it was, had a shop put it in.
Oxyg3n's comments concern me though, maybe Penzoil is the way to go. Don't see any issues mentioned.
jeepmor is offline   Reply With Quote
Old 02-06-2021, 07:29 PM   #41
randomthoughts
Drives: 2014 White BRZ
Thats the stuff!
Is this also the same? looks different but seems to have the same parts number
https://www.amazon.ca/gp/product/B00...A2SNKCOWT2PS9P
Is it possible to mix this with MT-90? I still have some MT-90 left and hate to waste it. I recall seeing a few people mixing but can't seem to find the post anymore.
randomthoughts is offline   Reply With Quote
Old 02-06-2021, 08:13 PM   #42
rice_classic
That’s it. May have diff p/n because Canada. It’s perfectly fine to mix.
SCCA T4 - FRS
randomthoughts (02-08-2021)
differential, fluids, maintenance, oil, transmission fluid
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 10:24 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 12:52 PM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 09:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 10:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
