Old 04-17-2020, 12:12 PM   #29
Pbrown
Drives: 2013 Scion FRS Raven
Originally Posted by solidONE View Post
Does it only happen when you actuate the clutch pedal? If so, then its likely to do with the TOB, clutch fork, or slave master. Either way you'll probably need to get to the clutch fork and TOB to inspect them. No way around it, my friend.
Bingo!!!!!
Pbrown is offline   Reply With Quote
Failing Sway Bar Bushing? jkost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-20-2021 04:14 PM
Suggestion for a failing clutch replacement neoknux_009 Engine, Exhaust, Transmission 6 10-04-2019 09:08 PM
Failing 02 sensor toast Software Tuning 17 05-13-2019 08:56 AM
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
