Old 02-28-2020, 06:08 PM   #29
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Im in the habit of rev matching 1st and 2nd when it is cold. I will blip the throttle just go to in first, and if second doesn't go in nicely I'll do the same. Seems to be working for me for years. Im about to change my trans and diff fluid next weekend with the same motul 300 that is currently in there. I'll update if I notice any difference.
DandoX is offline   Reply With Quote
Old 02-28-2020, 06:09 PM   #30
Feistyfrog
Drives: Toyota 86 2019
Originally Posted by wolffbite View Post
Wouldn't be a bad idea to check if your reverse lockout plate is aligned correctly based on your symptoms.
https://demos.starbase7.net/t3Portal..._rm_index.html
Drivetrain > TL70 Manual > Shifter Lever Assembly > Installation > 11. ADJUST SHIFT LEVER POSITION
A few people on here have had to adjust this plate on their stock shifter that was misaligned from the factory. I had to install and align mine after a short lived experience with an IRP shifter and have had no issues before or after.
I doubt the STI shifter itself is to blame. It's a direct drop in replacement of the OEM one into the same carrier, and uses the same plate. My money would be on the plate not being aligned properly.
Great link, very interesting!!
Feistyfrog is offline   Reply With Quote
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 04:48 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 05:24 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
