#29 | |
Drives: jrsc_brz
kidding aside you make great points about el vs uel that i had not known prior to your post, packaging etc. some still want to be in the uel boxer community more than they want 10hp tho im still oe header tho so dont shoot me, i can just see both sides. |
#30 | |
When I went looking for boost, the package I liked best, and which fitted my power goals, was the AVO, which damn it, has an UEL header. There were other options out there, but most had the turbo up high infront of the radiator, IMO they had a better header design, but the AVO just looks much more stealthy. So yeah, packaging compromise When I was NA I tried the Tomei header vs the OEM decat, that was a waste of $900AUD, the decatted OEM out performed the Tomei, everywhere. Most importantly is don't fall into the whole UEL header and extra torque hype. The conversations and actual gains are painfull. ![]() As always: Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#31 | |
Drives: 2002 WRX
That’s correct Sent from my iPhone using Tapatalk |
#32 |
Just try an OFT first. If you have regular e85 then ecutek+ tune + flex fuel is all you need.
2013 Series 10 FRS #553
#33 |
Damn that's crazy...
Drives: 2015 BRZ
Agree with this. Start small then build your way up. It would be great if you had access to e85, but start with the tune to help that dip if you’re scared to go catless. While you feel out the tune, you can do other mods to help the car’s performance like lightweight wheels, good tires, lighter exhaust, a drop-in filter etc. Punching out your cat is an option, but I personally would buy a catless header and swap out to stock when emission time comes just in case they want to give you shit about it. Whatever the case may be, you’ll be safe with a completely stock header. There’s lots of options when it comes to headers so you can make your own choice on that
#34 |
Drives: 2019 BRZ Limited 6 speed Red
Thanks jflogerzi and Will_BRZ! I'm going to do just that.
My read of the state emissions regulations doesn't detail the exact form of testing that's done. But when I brought my other car (2015 Mustang GT) for its emissions inspection, they did a tailpipe test. It could just be specific to my community, but after that, I'm leery of trying to get through without a cat (and also don't want to go through the headache of swapping headers for every emissions test; the more messing with the engine, the greater the chance for something to break). I've read a lot about the benefits of E85, but unfortunately, it's hard to find in my area. Thanks again! |
#35 | |
Only happy when it rains.
Drives: series.blue
The best thing to do is find an independent mechanic that you like that does the testing and just grow a relationship. That way if they like you they will look the other way if they can, and honestly tell you when they cannot. There are lots of good people that happen to do tests. There are also lots of assholes that don't give a shit that are using broken outdated decades old equipment that want to fail you. |
#36 | |
Drives: 2019 BRZ
This is not true. There has not been tailpipe testing in MA for more than 10 years. They scan for OBD2 codes (check engine light) and that's it for emissions. |
#37 | |
![]() Sent from my GM1915 using Tapatalk
#38 |
Only users lose drugs.
Drives: All the time
It's also not true that you can ask a buddy who has an inspection station and get a mail-order sticker. Only an idiot, or someone who doesn't care about losing his inspection license, would do that today. Mass inspection stations have something like 13 cameras scattered around the inspection bay, including at least one on the operator, recording the entire inspection process. If there's ever any question about the sticker on your car, the state goes back and pulls those records, and if fraud is determined, there goes your easy and guaranteed inspection income...
That being said, if you install a header and/or flash the tune, as long as there are 1) no codes being thrown, and 2) not a bunch of OBD log parameters turned off, they will never even bother opening the hood.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#39 |
Drives: 2018 BRZ tS
I ran a JDL Catted UEL and JDL UQ FP/OP combo pipe on 93. I made 194whp and 155ftlbs on a DynoDynamic Dyno with a custom tune.
Stock usually runs around 160-165 You can run clean, and still make good power. E85 is nice, but it's also more difficult to come by, and given you are in New England, it SUCKS in the cold. Also given this map (which isn't 100% accurate): https://afdc.energy.gov/fuels/ethano...arest?fuel=E85 there are not a whole lot of locations in NE, unless you happen to be in of the very few areas. JDL just re-released some catted headers. I'd recommend checking them out and going from there. I never threw a code, and never had any sensors disabled. |
#40 | |
Wes
Instagram: @gt86ws
#41 |
Drives: 2018 BRZ tS
#42 |
Wes
even more impressive then that you gained 30 hp. Usually that's the expected gain from a fully catless setup
Instagram: @gt86ws
| Join us for Gizdich Ranch Pie Run 7 (2019) -- Sat Aug 17, 2019 | PMok | Northern California | 11 | 08-20-2019 11:17 PM |
| 2019 Fiesta ST or 2019 Subaru BRZ | korhun | BRZ First-Gen (2012+) — General Topics | 97 | 08-02-2019 08:56 AM |
| Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited | Busybee | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 02-24-2019 12:05 PM |
| Is 75% tint worthwhile? (PA) | nalc | NY / NJ / CT / PA | 10 | 07-31-2013 04:13 PM |
| Earth Harness Systems, Worthwhile or not? | Panman | Engine, Exhaust, Transmission | 5 | 04-23-2013 05:32 PM |
