Old 11-06-2019, 03:23 AM   #29
Originally Posted by Takumi788 View Post
Good one! Have the coach show you how to read data properly.
Also, there is a bunch of literature out there. Speed Secrets Ultimate by Ross Bently is my favorite. I read is every off-season.
There's the level of data where you just read speed/throttle/brake/g-force traces, and then a level of data where you can go deeper into dampers, wheel speeds, cause and effect, and truly exploit the nuances of each individual car and track.
Scary part, is that this is all with data from a $700 AIM Solo/Solo2 DL.
HachirocksU (11-22-2019), Takumi788 (11-06-2019)
Old 11-06-2019, 03:24 AM   #30
Originally Posted by Icecreamtruk View Post
Coaching is good, not all coaches are good coaches, not all of them are focused on making you faster, some only know how to make you safer.
Mods are great as well, I believe improving the car along with the driver is a more effective way than to try and squeeze every ounce of performance of an otherwise stock car before changing anything.
Absolutely this.
Just how there are drivers all across the scale, there are coaches all across the spectrum as well.
Remember that most volunteer coaches primarily coach to get themselves cheaper/free track days! Many of them do have your best interest at heart, but watch for the ones who really don't care. Also, get input from MANY different experienced drivers and coaches.
Icecreamtruk (11-06-2019)
Old 11-06-2019, 03:29 AM   #31
Originally Posted by Mr.ac View Post
You don't need a "pro" all you need is a dude/chick that has way more track time and fast times just teach you some tips.
Originally Posted by iLuveKetchup View Post
"Pro" coaching seems silly (unless this is for a 5yr old on karts with aspirations to be in F1). Just have a more experience driver ride along and/or become a passenger for a session. Watch a ton of videos. Keep it simple and fun.
Originally Posted by TommyW View Post
Most track days offer free coaching
the old adage of "you get what you pay for" applies here. Not needing a pro coach is akin not not needing track brake pads to be on track.
The difference is a good pro will VERY quickly eliminate your bad habits, and give you plenty to work on going forward past the single day of coaching, that a volunteer coach will likely not see.
Someone who relies on coaching to make a living is far more incentivised to give the best possible experience, whereas a volunteer coach really suffers no consequence whether their student does well or not.
Icecreamtruk (11-06-2019), Takumi788 (11-06-2019)
Old 11-06-2019, 08:28 AM   #32
steverife
Drives: 2016 Scion FRS
Minimal track experience, but lots of autocross. And some coaching experience and formal coaching training outside of motorsports.
I think where free instruction sometimes comes short is there is often a one size fits all approach. Even with the best intentions, your instructor may not have the time or the broader perspective to learn and to cater to your goals, your learning style, your language, and your experience level.
steverife is offline   Reply With Quote
Old 11-06-2019, 11:11 AM   #33
Racecomp Engineering
Originally Posted by Apelsin View Post
I'd like that, a car which is more fun and helps focus on driving. But can you be more specific as to what exactly is a properly modified car?
Basically I mean a car that you don't have to worry about and you're not driving around major short comings.
So proper cooling and brakes you can trust are obvious things, but also a good alignment that allows you to get the most out of your tires. Tires that can take a little heat and don't go off too quickly. Also continued proper maintenance.
Your alignment and suspension should be built around your tire choice. Brakes too. For example, really sticky tires will still go fast on stock suspension, but you'll be wearing them unevenly and the chassis will be moving around a ton.
Data analysis helps a lot for both driver improvement and car set up, and there are different levels of that.
On that note, lots of suspension adjustment points are great when you understand what's happening to the car and can confidently make changes. This means knowing what you're going to affect directly and indirectly, in each phase of a corner AND how it will affect other corners. If you're not fully understanding what's happening to the car and what you're doing to it, more adjustment isn't necessarily better. On the other hand, if you do understand what's going on, more adjustment can unlock more potential in the car. Or work with an experienced suspension tuner.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
HachirocksU (11-22-2019), i8ur911 (11-06-2019), Tristor (11-06-2019)
Old 11-06-2019, 11:29 AM   #34
TommyW
TommyW's Avatar
Drives: '13 Whiteout
True. I think it depends on your level of driving. A novice or intermediate may be fine with a track day coach however once past that a pro may be necessary.
A lot of great drivers coach out of financial necessity. They may be phenomenal drivers however that doesn’t always equate to being a great coach. This I was told by one of the best drivers\coaches in the biz, not from personal experience.
The Following User Says Thank You to TommyW For This Useful Post:
CSG Mike (11-10-2019)
Old 11-06-2019, 11:34 AM   #35
This is true about a lot of things in life. Some people just can't teach.
- Andrew
Old 11-06-2019, 08:43 PM   #36
Apelsin
Drives: Jeep
PM me and we can discuss your coaching needs, and see if I'm a potential good fit.
PM sent but not sure it can work out since we are on opposite coasts. Any recommendations on how to find a pro coach on the east coast?
Apelsin is offline   Reply With Quote
Old 11-06-2019, 08:49 PM   #37
i8ur911
Drives: 17 BRZ Series.Yellow
Where are you on the east coast, North or South?
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 11-06-2019, 09:40 PM   #38
Apelsin
Drives: Jeep
Middle
Old 11-10-2019, 05:53 PM   #39
i8ur911
Middle
If you're in the NJ area, you can reach out to the local NASA group. I know AZP Installs runs their own events and the owner also tracks am 86.
Old 11-10-2019, 06:31 PM   #40
lextrueno
lextrueno's Avatar
Drives: 2013 Firestorm Frs
Another point that I don't think many have addressed yet is if you live in an area where weather limits track time, it is a good idea to invest into a entry level sim rig. You can get a lot of seat time playing gran turismo or iRacing just by using a decent seat and force feedback wheel. I know this isn't the perfect way to learn/gather data. But I think for the money you can develop your race craft in a fun, safe learning environment with no extra costs for consumables like brakes and tires. Also some coaches can work with you through those games to analyze your line and help you focus on certain aspects of your racing.
Assuming you have nothing:
Racing Seat with mounts for wheel/pedals - $230-$500 dollars
Thrustmaster T300 Ferrari - $400
PS4 with Gran Turismo -$330 (Black Friday sales would be a good time to pick one up)
lextrueno is offline   Reply With Quote
The Following 3 Users Say Thank You to lextrueno For This Useful Post:
HachirocksU (11-22-2019), strat61caster (11-10-2019), TunaNoCrust (11-11-2019)
How much faster is a Pro Driver in your own car? EFIxAndy Tracking / Autocross / HPDE / Drifting 20 06-18-2016 11:43 AM
Keep car N/A or buy another faster track car Sonolin Scion FR-S / Toyota 86 GT86 General Forum 29 02-19-2014 05:13 PM
Here's for those who want to go faster.. :( slidethis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 01-08-2013 05:22 AM
FRS faster than BRZ? Tell me why I should still get the BRZ. Phaedrus29 FR-S / BRZ vs.... 63 04-27-2012 11:50 PM
