Old 02-27-2014, 10:12 PM   #29
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ok so I figure ill add to this thread. I had the same problem and pulled everything apart in the same way but...the plastic reciever box was buzzing against the actual pc board! So I potted it in epoxy problem solved, problem staying solved.
Old 10-13-2019, 03:48 PM   #30
Suparu
Drives: 2013 BRZ Limited
I pulled apart the rear deck shelf and gently pryed every metal gap with a flathead until the metal cracking sound would stop. Then filling it with white lithium grease and eventually spray foam when sound persisted.
My wireless receiver was tight and didn’t make any sound when I moved it by hand. But I removed it anyway and put some foam weatherstripping under it. Now my car’s rattle free finally.
I’ve realized the rattles vary between 86’s but there’s some great posts on this forum to help. I’ve been hunting creaks/rattles for the past month and I think I’ve finally addressed them all. I had to hit several different problem areas in the trunk and rear deck shelf. Now I’ll put the plastics back one at a time and deal with plastic rattling as I encounter it. Hopefully there will be no additional rattles from the plastics as I put it back together. But my experience so far has been the opposite, especially since my BRZ is a 2013 model. But man it feels good to have a creak/rattle free car!
What threw me was some of the metal freaking sounded like it was coming from above the B pillar but turned out to be the wireless receiver which seemed snug and tight in my case. But apparently it was a source of racket after all.
Suparu is offline   Reply With Quote
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 10:48 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 05:55 AM
solution to the ugly taillights beirouty Cosmetic Modification (Interior/Exterior/Lighting) 107 05-04-2014 04:42 PM
My Front Plate Solution Flat Black VW BRZ First-Gen (2012+) — General Topics 55 11-06-2012 10:07 AM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 05:35 PM
