Old 09-18-2019, 10:36 AM   #29
imped4now
Drives: '17 BRZ PP - '17 FoRS
I actually just made the same move, and even spoke to the OP on the Miata forum prior to doing so. 2017 BRZ PP to 2019 RF Club w/ BBS/Brembo and Recaros. My thoughts:
Agiity - The ND is the smaller, lighter car. But it's not like the BRZ is a porker that can't turn. We're splitting hairs.
Fuel Consumption - Miata is around 15-20% more efficient. I still consider the BRZ to be quite efficient.
Noise - Miata is a bit louder.
Handling - The BRZ is the overall winner. Flatter cornering, better on-center steering feel, and less jittery. The BRZ has one of the more impressive chassis I've experienced and it's top-shelf from the steering and brakes to cornering abilities. The Miata needs springs and sway bars at a minimum to match the BRZ's capabilities.
Acceleration - Miata has a midrange. It feels faster.
Engine Harshness - No major observations.
Seat comfort - My thoughts on the BRZ's seats are similar to the OP's. They are *perfect*, even for my larger (6'2" 210 lb) frame. Great lumbar support, great driving position, great comfort even on longer drives. The ND Recaros are good, maybe an 8 while the BRZ seats are a 9. I need to lower my Miata seats 1" in order to be able to sit in the car properly. At that point, I think they'll be tied.
Outward visibility - RF has the driver side blindspot. No other major notes.
Headlight brightness - I have yet to drive the Miata at night, but the LED BRZ headlights are absolutely top-shelf. Probably the best I've ever used.
Steering (turn-in, under-steer, over-steer) - The BRZ is the winner here, period. Steering effort and feel is superb, as is the on-center feel and return to center. The Miata isn't quite there but I do believe stiffer sway bars will really make a difference. I also hate the Miata steering wheel, which is at the top of my list.
High speed stability (against cross-wind) - The BRZ is the more planted car at highway speeds and there's really no question. The Miata isn't bad at all (I drove it home 500 miles at 80-85mph) but it does require more focus.
Shifter - my BRZ had the STI short shifter, shift lever/support bushings and trans mount spacer. It was absolutely superb in all areas. I preferred it to everything I've ever driven, including an S2000 (of which I spent several hours driving) and the ND. The ND shifter is very good but it doesn't have the weight, feel or precision of the BRZ's shifter. It's lighter sprung and requires less effort. I'll work on that.
Brakes - The BRZ PP is a braking beast - awesome feel, modulation and bite. The ND Brembos don't feel as good, so I plan on new pads and fluid to start. The BRZ feels premium in this area.
To get the ND to the BRZ's level of crispness, feel and handling, it needs a different steering wheel, pads, stiffer sway bars, and probably springs. However, it has a couple things the BRZ can't have - open air, a major diet and looks to die for. I hope this helps people that are in the same boat. I still believe you'll be hard-pressed to find a better driver's car for $20k than a 17+ BRZ PP.
imped4now is offline   Reply With Quote
The Following 2 Users Say Thank You to imped4now For This Useful Post:
JesseG (09-18-2019), joro2 (09-21-2019)
Old 09-18-2019, 11:39 PM   #30
Decep
Drives: 2013 FR-S Series 10
My mom's ND is a blast to drive, the engine is definitely a generation ahead of the FA20 in terms of power delivery and smoothness. The transmission is butter smooth. The ride is marshmallow soft.
It's too damn small, trunk is a joke. Passenger seat is a joke with that transmission tunnel. Legroom is tough and im not super tall or anything, 32" inseam. Big size 14 feet though so i feel clumsy driving it and have to be careful which pedal im pressing. Lovely toy but for me that's what it is. Do i take it out every chance i get? Of course
Old 09-19-2019, 04:25 AM   #31
~el~jefe~
Drives: 2019 MX-5 RF
There is no way without smoking a lot of bad NJ newark crack that you could find the BRZ shifter to be better than the mx-5.
The handling is crisper on the BRZ. Absolutely. The MX-5 Handles better. It just feels bizarre. The BRZ handles in a more enjoyable way. The MX-5 can take turns at insane speeds. It just feels like youre going to die, but never do.
Also, the electronic stability control on the MX-5 does not need to be turned off when you drive it very hard. It is similar to Track mode on the BRZ, but you dont have to hit the button.
Overall the BRZ is more pleasant to drive. It is. I wont deny that. Unless you want to go absolutely nuts and just robbed a bank. Then you need an MX-5 and ignore the bizarre sensations. You will outrun most things on the road, quite high end things 3x more in price.
~el~jefe~ is offline   Reply With Quote
Old 09-19-2019, 09:29 AM   #32
imped4now
I had the factory STI short shifter, along with the shift lever bushing and trans mount spacer. I prefer a higher effort, notchy shift feel and the BRZ is perfection. The Miata shifter has a little radial play that I'd like to take out, and the effort is pretty low. It all depends on preference, but at this point the BRZ is really the better car from the input side of things (brakes, shifter, steering). I'll get the Miata where I want it to be, it'll just take some work.
Old 09-20-2019, 04:19 PM   #33
Chikna
Drives: 2018 BRZ TS 244/500
I bought 2018 BRZ tS (205hp) for $30K, where will I get Miata RF Club (180hp) for $30K?
Chikna is offline   Reply With Quote
Old 09-20-2019, 05:01 PM   #34
norcalpb
norcalpb's Avatar
You guys should share with the class the process of replacing the front sway bar on an ND Miata.
Teaser: the quickest way to remove it is to cut the stock bar in half.
Old 09-23-2019, 05:31 PM   #35
~el~jefe~
you do realize that the Miata RF Club accelerates much faster, yes? Why do people quote hp. My car weighs 2430 lbs and has a flat torque curve.
I believe that people should have both a BRZ and a RF Club, or BRZ and a soft top Miata Club or grand touring (Leather and some fluff).
Old 09-24-2019, 04:31 AM   #36
86MLR
86MLR's Avatar
An RF will be on my short list in a couple of years.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 09-24-2019, 02:34 PM   #37
~el~jefe~
It really is the car to get. I can't think of any cars I want to collect aside from:
New BRZ
New Supra
New RF Club (or GT with the Club suspension upgrade)
That's about it.
Old 09-24-2019, 02:36 PM   #38
New BRZ
New Supra
That's about it.
Until you are bored with it in a year or so and then something else will be the one to get.
Old 09-24-2019, 03:18 PM   #39
~el~jefe~
Like a cat who can't decide to be in or out of the room/ door open or close.
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
Tcoat (09-24-2019)
Old 09-24-2019, 06:19 PM   #40
86MLR
86MLR's Avatar
LOL, this is me
3 to 5 years then it's out the door to be replaced with my next toy car
The Following User Says Thank You to 86MLR For This Useful Post:
Tcoat (09-24-2019)
