#29 |
Drives: Q5 + BRZ + M796
Let's also examine the evolution of the EL JDL headers:
4-1 EL Header ***WRONG INFO: THERE IS NO OLD AND NEW HEADER. THIS PIC IS AN OPTICAL ILLUSION. SEE THE CONVERSATION THAT FOLLOWS*** 4-2-1 EL Header (old)...there is an equal length to each stage of the runners. 4-2-1 EL Header (new)...there are longer runners with a merging of the pipes to a single pipe at the very end.
#30 |
Because compromise ®
Drives: Red Herring
| The Following 4 Users Say Thank You to Captain Snooze For This Useful Post: |
#31 | |
2013 Series 10 FRS #553
#32 |
I don't have dyno graphs to compare. I was only speculating based on the data we do have.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | jflogerzi (11-24-2019) |
#33 | |
Good Job Subaru!
Drives: '24 CX-50 Meridian
There is only 1 version of the 4-2-1 EL Header. Although it is not apparent in the photo, that cerakoted header has its merge right at the exit to the overpipe, just as the uncoated header below that (that was the prototype). My 4-2-1 header:
| The Following User Says Thank You to JBezugs For This Useful Post: | Irace86.2.0 (11-25-2019) |
#34 | |
#35 | |
Good Job Subaru!
#36 | |
#37 |
Well I have one on order and will try and get in on the Dyno.
#38 |
Good Job Subaru!
Look forward to results! Are you picking up an overpipe as well? I have the stock OP on my JDL 4-2-1 setup currently, but I'm wondering whether or not I should pick up an aftermarket unit in the spring.
I've heard from many that I've made a "huge" mistake by keeping the stock OP paired with my header and that I'm losing precious ponies... I'm still going to keep my stock FP in place however.
#39 | |
#40 |
4-2-1 in and much prefer it over my old tomie UEL. Still using my old tune so it's not optimized for the new header. But the car just runs much better and feels even smoother. Sounds better to. I will see if and when I can get a Dyno done on my setup.
| The Following User Says Thank You to jflogerzi For This Useful Post: | JBezugs (12-16-2019) |
#41 |
Drives: 2002 WRX
Ok
#42 |
Drives: 2002 WRX
Ok.
| My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 05:09 PM |
| Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 05:57 AM |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 07:54 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| My Fr-s Dyno Results!! Surprising if you ask me | track_warrior | Engine, Exhaust, Transmission | 36 | 07-02-2012 11:15 PM |
