Old 11-21-2019, 06:23 PM   #29
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Let's also examine the evolution of the EL JDL headers:
4-1 EL Header
***WRONG INFO: THERE IS NO OLD AND NEW HEADER. THIS PIC IS AN OPTICAL ILLUSION. SEE THE CONVERSATION THAT FOLLOWS*** 4-2-1 EL Header (old)...there is an equal length to each stage of the runners.
4-2-1 EL Header (new)...there are longer runners with a merging of the pipes to a single pipe at the very end.
Old 11-22-2019, 06:35 AM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
churchx (11-22-2019), Irace86.2.0 (11-22-2019), sato (11-27-2021), ScoobsMcGee (12-18-2019)
Old 11-24-2019, 05:06 PM   #31
jflogerzi
jflogerzi's Avatar
Maybe I am confused, but it looks like the Ace 4-2 header and 2-1 overpipe is $1700, and the JDL 4-2-1 header and "1-1" overripe is $1500. The JDL 4-2-1 header is $1200. It seems like $200 is worth the difference.
I think it is worth it to describe these headers better. The Ace is not a 4-2-1 header. As I said above, it is a 4-2 header, which works with their 2-1 overpipes, and that overpipe varies, such that the 150/250/350 progressively adds more length to the two pipes before they merge.
The JDL header is maximizing the runner length as much as it can for the limits of a 4-2-1 header by merging to a single exit at the last possible inch. (Estimated from the pictures) The JDL header merges about 4-6 inches sooner than the Ace 150, which merges about 4-6 inches sooner than the 250, which merges about 4-6 inches sooner than the 350. Also, the Ace header has 4 pipes for three-quarters or more of its length, where the JDL has 4 pipes for about one-half its length.
My guess is that we could plot the differences on a dyno between the 150/250/350 and extrapolate that the JDL would be equivalent to a 50 in the lineup, such that JDL50/Ace150/Ace250/Ace350 would follow like so. With that said, if your setup was ideal for the 150 over say the 350 then the JDL setup could also be ideal, but if the 350 was already better than the 150 than the 350 will be even that much more better than the JDL.
I don't see any results just pictures. You mind sharing?
2013 Series 10 FRS #553
Old 11-24-2019, 06:52 PM   #32
Irace86.2.0
I don't have dyno graphs to compare. I was only speculating based on the data we do have.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
jflogerzi (11-24-2019)
Old 11-25-2019, 11:51 AM   #33
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
4-1 EL Header
There is only 1 version of the 4-2-1 EL Header. Although it is not apparent in the photo, that cerakoted header has its merge right at the exit to the overpipe, just as the uncoated header below that (that was the prototype).
My 4-2-1 header:
JBezugs is offline   Reply With Quote
The Following User Says Thank You to JBezugs For This Useful Post:
Irace86.2.0 (11-25-2019)
Old 11-25-2019, 12:26 PM   #34
Irace86.2.0
My 4-2-1 header:
So you are saying JDL never produced this header from the picture I refer to as the old 4-2-1 header? You are saying it was just a prototype that was never released? If this isn't what you meant than I am confused as to what you are trying to say. Or are you saying the picture is an optical illusion because the other merger pipe is visually superimposed on the other, so it can't be seen?
Old 11-25-2019, 12:51 PM   #35
JBezugs
Good Job Subaru!
JBezugs's Avatar
The photo of the old (cerakoted) header is an optical illusion; Because of the way the merge collector by the overripe flange is positioned relative to the angle of the photo, you can't actually see the final merge. Looking underneath the header from a different angle, you can see it.
Old 11-25-2019, 01:56 PM   #36
Irace86.2.0
Gotcha, thanks for clearing that up.
Old 11-26-2019, 06:59 PM   #37
jflogerzi
jflogerzi's Avatar
Well I have one on order and will try and get in on the Dyno.
Old 11-26-2019, 08:26 PM   #38
JBezugs
Good Job Subaru!
JBezugs's Avatar
Look forward to results! Are you picking up an overpipe as well? I have the stock OP on my JDL 4-2-1 setup currently, but I'm wondering whether or not I should pick up an aftermarket unit in the spring.
I've heard from many that I've made a "huge" mistake by keeping the stock OP paired with my header and that I'm losing precious ponies... I'm still going to keep my stock FP in place however.
Old 11-26-2019, 10:02 PM   #39
jflogerzi
jflogerzi's Avatar
Don't plan to. Going to talk with my tuner. It's not worth 5-10 whp
Old 12-15-2019, 11:10 PM   #40
jflogerzi
jflogerzi's Avatar
4-2-1 in and much prefer it over my old tomie UEL. Still using my old tune so it's not optimized for the new header. But the car just runs much better and feels even smoother. Sounds better to. I will see if and when I can get a Dyno done on my setup.
The Following User Says Thank You to jflogerzi For This Useful Post:
JBezugs (12-15-2019)
Old 12-18-2019, 11:05 AM   #41
Denver20
Drives: 2002 WRX
Ok
Denver20 is offline   Reply With Quote
Old 12-18-2019, 11:05 AM   #42
Denver20
Drives: 2002 WRX
Ok.
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
