| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
Drives: 2017 86 860 Special Edition
All that said and done, it's a totally different experience driving the car. I can sit back comfortably, and the steering wheel is positioned perfectly, not to mention it no longer hits my knees so I have full rotation and can apply proper torque while driving. I kind of wish I got it ages ago. Any one on the fence about getting this should buy it immediately. If you've never quite been comfortable and felt the steering wheel was too far or you were leaning forward to wrestle the steering wheel this is the answer! Great job @949 Racing! |
| The Following 2 Users Say Thank You to RayRay88 For This Useful Post: | 949 Racing (06-11-2021), Thefalls (06-07-2021) |
#30 | |
Drives: 2015 Scion FRS
I had the same issue, it would unplug when trying to install the airbag, how do you fab up this extension? What parts needed? |
#31 |
Drives: 2013 Subaru BRZ
This is a great thread. It's too bad the large versions of the images no longer works. That would be been super helpful.
I'll be installing mine tomorrow. I hope I can get my big mitts in there to handle some of the wiring tricks. |
#32 |
For anyone still reading this, I worked this out. I went to the trouble of getting all the images from the unreliable image host and combined all of this into a single document. There have also been changes with the 949 hub extender. If there is any interest in having this in a single doc, just message me and I can update the doc a bit and make it into a PDF and send it to you.
#33 |
To everyone, I have converted this into a document you can download and print. I made the images larger so they are easier to see.
Keep in mind that 949Racing has made revisions to their product but it's not hard to understand the minor differences. @Clutch Dog thanks for putting this together in the first place. @daskaman here is the document you messaged me about. |
| The Following User Says Thank You to RT-BRZ For This Useful Post: | daskaman (08-24-2024) |
#34 | |
Drives: Burz
| The Following User Says Thank You to daskaman For This Useful Post: | RT-BRZ (08-24-2024) |
#35 |
I found it to be a bit of a stretch by it worked OK for me. The horn is definitely functional. I also swapped steering wheels while I was at it because I didn't want to take this apart again later.
| 949 Racing 50mm Steering Spacer 86 - GR86 | 949 Racing | Tracking / Autocross / HPDE / Drifting | 195 | 04-18-2022 12:45 PM |
| Spacer install | EzyBrzy | Northern California | 1 | 03-05-2016 04:52 PM |
| Vibrations After Spacer Install | Wyattkb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-08-2015 01:20 PM |
| RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? | 20valvewynn83 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-07-2013 05:33 PM |
