Old 07-14-2019, 03:13 AM   #29
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
Originally Posted by jflogerzi View Post
2013 series 10 65k on obo. 3rd owner. Boosted at 10.5psi and e85. Knock on wood. Tuner said logs looked great and he left a bit on the table for safety. 1500 miles so far car drives better than stock. @Xero-Limit Mike did a fantastic job with my etune
Run a vin check, the car might have gotten the valve work for the recall that was posted already done. Assuming everything on the block works the way it's supposed to the first thing that should go out are the rods.
I've also seen a lot of people with spun bearings and nasty rod knocks because of it but that's because they didn't keep their oil temps in check or starved the engine of oil during sustained high G turns at the track.
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
Old 07-14-2019, 03:17 AM   #30
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Flashfire88 View Post
Hey bud,
For reference my BRZ had an avo turbo kit and I was doing 12.5psi towards the last year I owned it, I slapt it on the car as soon as it hit 2 months right after I bought it new so around 2,000ish miles. I would track it often and for the 4 years I had it I never ran into a problem. The ONLY issue I had was that my clutch starts slipping at 3.5K and would grab again at 4K so that had to get upgraded.
Also Florida heat so the car was in constant 90+F temps during summer and 75+ during winter season. I would say get a really good reputable tuner.
Edit:
Forgot to mention 93 Octane & Stock block
Now search for the OP's most recent topics.
I'm currently estimating around an 80% chance the motor isn't going to see new years eve from within the engine bay.
Old 07-14-2019, 03:18 AM   #31
jflogerzi
jflogerzi's Avatar
It was not affected by the value spring. Already checked the bank vin. I have a JC racing dual radiator. On the next change I am going to change the oil pan to a baffled one. So I am hoping I have done everything on the supporting mods. Running 5w30 and have adjusted the fans to come on sooner with the tune.
2013 Series 10 FRS #553
Old 07-14-2019, 03:57 AM   #32
ZionsWrath
Thanks
ZionsWrath's Avatar
I money shifted mine and it ran two years of track use before engine started knocking. No oil consumption or other signs of a problem except when it started making loud knocking two years later.
It may seem like the engine is made of glass when you look for these engine blown threads but it really isn't bad.
Oh, mine was a 2013 bought May 2012, first production run.
Hope this helps.
Old 07-14-2019, 04:05 AM   #33
kev0
Drives: '14
Eh, most issues have been fixed. ABS and Slip light was due from a tune. Had the SC 'rebuilt'. Only issue now is running lean from leaky intake pipe. If it blows, I'll deliver you a rod since I'm in Chicago as well.
kev0 is offline   Reply With Quote
Old 07-14-2019, 04:11 AM   #34
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
So if you don't mind me asking, has the total repair cost/install still lower than if you bought a new SC kit? Or ... more expensive?
Or should I haven't even ask cause I kinda know what the answer is?
Old 07-14-2019, 04:21 AM   #35
kev0
Drives: '14
A bit under $1000 for install + SC rebuild (resealing SC and new gaskets)
Ease the ride? frosty86 Engine, Exhaust, Transmission 21 12-27-2013 07:43 AM
Mind-blowing features of the next model BRZ Baldoak BRZ First-Gen (2012+) — General Topics 89 08-28-2013 07:59 PM
2nd gear powerslide ease? civdaddy Scion FR-S / Toyota 86 GT86 General Forum 22 11-02-2012 04:40 PM
Ease of removing stock exhaust Evil86 Engine, Exhaust, Transmission 3 06-07-2012 10:05 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 12:16 PM
