Old 10-06-2019, 03:23 AM   #29
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Hey @norcalpb and @7 skulls, can you provide an update on the pedders hats? How are they holding up? Any additional noise, problems to report?
BlueWhelan is offline   Reply With Quote
Old 10-06-2019, 04:08 PM   #30
7 skulls
Drives: 2014 scion frs
Can do. It's been roughly 5000km (3000 miles) since the install and everything is just a tight as day one. No weird noises or problems so far. Front tire wear seems fine but I will check this more closely when I change to my winter wheels in a few weeks.
Performance wise, the turn in is still immediate. I haven't been to an autoX since the install due to work commitments but with MPSS (stock size), there is now more front grip than you can safely exploit on the street. As a plus, it's easier to get the back end around. Anyone who has driven my car before/after always comments on the quicker steering. At higher speeds, it is almost too quick now, two hands on wheel,
7 skulls is offline   Reply With Quote
Old 10-06-2019, 11:12 PM   #31
norcalpb
norcalpb's Avatar
Things have been great so far with the top hats. No additional noises, and like above the handling is great. I just love how compliant they are. IMO these are the DD/sport driving go-to. I;d say I've put 7k miles on these so far.
I have really soft STi springs but plan to upgrade to a coilover setup where I can incorporate these top hats and maintain comfort in that area on my way to work.
Old 10-29-2019, 05:12 PM   #32
7 skulls
Uneven wear...
Been away for 4 weeks without the car and just got back a few days ago. While changing the oil, I noticed some uneven wear on the inside of my front tires. Looks like almost 2 deg of camber might be too much for daily driving. My toe is within spec so that shouldn't be the problem. Everything I have read here says that 2 deg negative camber should be fine for a daily driver. I guess not. Next spring, (the car is not winter driven) I will have the alignment checked again and possibly got back to just the top hats with the stock camber bolts. Anyone else having this trouble?
Old 10-29-2019, 07:10 PM   #33
strat61caster
strat61caster's Avatar
That's about what my tires look like at the end of their life at -4°
'toe in spec' does not mean it's right, what's the actual toe value?
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
7 skulls (10-29-2019), BlueWhelan (10-29-2019), x808drifter (10-29-2019)
Old 10-29-2019, 07:38 PM   #34
7 skulls
0.08 and 0.07 degrees with total toe at 0.15. The car is more nervous at speed so I am hoping this is a toe issue but have no idea what toe I should be shooting for.
Old 10-29-2019, 08:49 PM   #35
strat61caster
In or Out?
ineedyourdiddly
Old 10-29-2019, 09:32 PM   #36
7 skulls
[QUOTE=strat61caster;3270873]In or Out?[/QUOTE
Value is positive so toe-in.
The Following User Says Thank You to 7 skulls For This Useful Post:
strat61caster (10-29-2019)
Old 10-29-2019, 11:51 PM   #37
strat61caster
In or Out?
Could probably chop that in half closer to zero to improve tire wear, I've found the highway stability has more to do with the rear toe than the front, I've been happy with about +0.25° toe in the back and 0° in the front when it comes to highway stability. Right now at 0°F & +0.15°R and there's a bit of tramlining but part of that is the high camber I have in the front at -4°
All toe numbers are total, imho as a conservative change 'closer to zero toe front, more toe in, about 0.25°' would be a good step forward.
ineedyourdiddly
7 skulls (10-30-2019)
Old 10-29-2019, 11:56 PM   #38
BlueWhelan
BlueWhelan's Avatar
I agree with the above. Zero toe front, slight toe-in rear. Toe will kill tires much faster than camber will.
On a lighter note, I got my top hats in on Friday! Now I just need to find some time to install and align...
The Following 2 Users Say Thank You to BlueWhelan For This Useful Post:
7 skulls (10-30-2019), norcalpb (10-30-2019)
Old 10-30-2019, 11:55 AM   #39
7 skulls
Appointment booked for tomorrow at the garage. Zero toe front is the goal. Just rotated my tires as well.
Old 10-31-2019, 06:53 PM   #40
7 skulls
Alignment done today.
Same garage, same machine, different, more experienced tech. More camber than the last alignment scan. Had him zero front toe and it made an immediate difference to how the car drove: less twitchy at highway speeds, no more of what felt like bumpsteer across road undulations in turns. Turn in is a little slower but front grip remains the same. Not bad for $84.
On the way to the garage, I shared the road with a heavily modded MK3 Supra. 600 whp is no comparison to 200 at the crank.
The Following 3 Users Say Thank You to 7 skulls For This Useful Post:
BlueWhelan (10-31-2019), norcalpb (10-31-2019), Racecomp Engineering (10-31-2019)
Old 10-31-2019, 10:04 PM   #41
norcalpb
norcalpb's Avatar
I’ve heard that having more caster on the right is better for a DD as it helps fight the crown of the road.
Maybe RCE can chime in ��
Old 11-01-2019, 05:15 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
More caster does two good things, makes steering more tending to self-return to center, and increases dynamic negative camber gain on top of static camber for turned wheels, allowing to use less static camber, resulting in more even contact patch both in straights & in turns.
In some uses those changes might be considered as negative though. For example - it will make steering heavier, which some might not like, will overwork powersteering more (some of earlier twins on sticky tires / lot of caster had issues on track with PS overheating and switching off to cool down), and too much of a caster's induced dynamic camber gain might be detrimental if one needs opposite for that, eg. in drifting, where outer tire is one countersteered "opposite way".
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 05:35 PM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 10:06 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 06:03 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
