#29 |
Drives: None
As others have said, you'd want to get max camber up front. But instead of one pair of camber bolts, get two sets (for top and bottom). I was able to get -2.9 this way. Very cheap way to get better tire wear.
| The Following User Says Thank You to Jamestl For This Useful Post: | strat61caster (05-03-2019) |
#30 |
Dismember
Drives: 2013 Red Scion FR-S
Some people say it might not hold the settings well that way, though.
#31 |
Drives: 2015 FRS
I've read every thread I could find (and I don't suck at searching on the intarwebs) the more I read, the more confused I get as to which size bolt to buy (14 vs 16mm) and which hole to use (top vs bottom). Then some people say both. Others say camber bolt in bottom, then move bottom stock bolt to the top....
#32 |
Dismember
If I recollect correctly, camber bolts are usually for the bottom. You can get a crash bolt that uses a real Subaru part or a camber bolt that is lopsided. Then if you want, the smaller stock bolt can replace the larger top bolt, but then you have two places that can potentially slide instead of one, ruining your suspension setup.
#33 | |
Drives: 2017 Subaru BRZ Limited
#34 | |
Drives: 2016 Subaru BRZ Series.HyperBlue
Two bolts connect the knuckle to the strut. The lower bolt/hole is 14mm and the upper bolt/hole is 16mm. (No slop or adjustment) Not every camber bolt kit description specifies which size it is, but the instructions should tell you which hole to use, so that would let you know the size. So you have three commom options: 1. Replace lower bolt with an eccentric/lobed 14mm bolt. 2. Replace upper bolt with an eccentric/lobed 16mm bolt. 3. Replace lower bolt with an eccentric/lobed 14mm bolt and move the original 14 mm "crash" bolt to the upper 16mm hole. This would give you extra play in the top bolt for adjustment. Slightly risky as you are relying on the friction and tension of the bolt to hold position rather than direct contact. |
| The Following 2 Users Say Thank You to Vesartis For This Useful Post: | CrowsFeast (08-16-2019), showrun (04-24-2019) |
#35 | |
Drives: None
Also camber gained via at the hub is better than at the plates as the plates will gain more camber when the wheels turn. |
#36 |
Drives: 17 BRZ Series.Yellow
Others have mentioned it, but I'd highly recommend a set of Michelin Pilot 4S's or even the Conti Extreme Contact Sport (looks identical to the Pilot 4S).
Both tires will give you plenty of slip angle to help with learning and car control as well as be good in the rain. Sent from my Pixel 3 using Tapatalk |
#37 | |
Drives: 2020 GMC Canyon Denali Diesel
That being said tire pressures and temps need to be monitored between sessions and adjusted as needed. Have been running -2.1 camber in the front and -1.9 in the rear.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#38 | |
I'm running the SPC lobed bolt in the bottom hole, stock bottom bolt in the upper hole on KW V3's and it maxed out at -3.8*. It's dialed back to -3.2* by the bottom lobed bolt, and is actually SUPER easy to adjust on the alignment rack. Don't have to lift the car or anything. They've been on for about a year and zero signs of slippage.
| The Following User Says Thank You to wparsons For This Useful Post: | strat61caster (05-13-2019) |
#39 |
Drives: 2013 WRB BRZ
I had Maxxis Victra VR1s on my car for a while and loved them. I only AutoX'd with them, but I know there are a few people on here that use them for HPDE and track days.
| The Following User Says Thank You to BigTuna For This Useful Post: | lextrueno (09-15-2019) |
#40 |
Only users lose drugs.
Drives: All the time
I have to say, what the RT615 K+ lack in outright grip compared to the hero tires like Rival S and RE-71R, they more than make up for in consistency, durability, and as such, great value as a track tire. It's not like you'll go wrong with them, that's for sure. I'm driving the piss outta mine (~1:24 laps at Thompson), and they look fantastic after 6 or 7 half track days...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#41 |
Drives: 2013 pearl white FR-S
i have a few friends running the Toyo Proxes RR for track... so far so good
#42 | |
Drives: 2018 Gt86
I've got 5 track days and 20K miles of commuting on the stockers. They are about done so this thread is relevant to me. It's finally hot enough (on the brakes hard enough?) that I've felt them go greasy. If your ok with not getting griptastic ~200tw tires the dilemma becomes finding a hard/street tire that doesn't go away when it's hot. Nobody talks about that because we all buy "track day tires" for the track. I'd love to know if the traditional summer street tires like the PS4S or Continental equivalent will hold up to the heat generated by a stock powered 86 without the grip giving out and me wasting a 7/10th lap to get them to come back. |
| The Following User Says Thank You to dpaqu For This Useful Post: | strat61caster (05-15-2019) |
| 2019 Toyota 86 TRD Edition | stevesnj | Scion FR-S / Toyota 86 GT86 General Forum | 265 | 12-04-2019 04:38 PM |
| Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited | Busybee | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 02-24-2019 01:05 PM |
| 2019 Special Edition BRZ, any ideas??? | Stephen W. | BRZ First-Gen (2012+) — General Topics | 126 | 08-06-2018 05:39 PM |
| 2019 Toyota 86 TRD Edition | interna | CANADA | 8 | 07-08-2018 10:02 PM |
| FS: (4) 17x7.5 Sport Edition SE-16 w/BFGoodrich g-Force Tires | Doug&Julie | Wheels and Tires | 4 | 05-26-2014 07:37 PM |
