Old 11-13-2019, 09:36 PM   #29
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
OK.
So, do you hear the sound only when the engine is running? Does it matter if the car is moving or not?
Did you follow up on Tcoat 's idea that it may be the head units cooling fan? Maybe pull the fuse for the radio to see if it makes a difference.
humfrz
I’ll try and give that a go. But to answer your question, it’s only when the engine is running and up to temp in cold weather. There are times you can hear it when you’re moving, but most of the time it’s drowned out by engine noise. If I rev slightly, it seems to speed up the noise or make it a higher pitch at times.
DaBoBo21 is offline   Reply With Quote
Old 11-13-2019, 10:54 PM   #30
humfrz
OK.
I suggest you try to describe the sound you are hearing and give examples of what it sounds like.
humfrz
Old 11-13-2019, 11:21 PM   #31
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
OK.
humfrz
Honestly, the best way I know to describe it (because I can't find any other videos out there to help describe the noise) is just a chirping pump.. the chirping increases in speed and pitch when you give the car gas and it's always there.. My guess is the sound is coming from behind the firewall where the engine sits. I'm not that mechanically inclined to know what this could be. When you pop the hood all you hear is the sound of DI working, no chirping. I just took another video after a quick trip to the store and will post it here in the next few minutes.
Old 11-13-2019, 11:24 PM   #32
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Here you go.. if you listen to the end you can hear what I mean about a chirping pump shutting off
Old 11-14-2019, 12:27 AM   #33
humfrz
OK, I heard a metallic clicking sound at the end of the video. Is that what you hear while the engine is running?
Maybe others with better hearing will chime in.
humfrz
Old 11-14-2019, 03:31 AM   #34
JD001
JD001's Avatar
Drives: Subaru BRZ
humfrz
I can't hear it.. just "normal" diesel chatter...
Chirping. _anthonygd BRZ First-Gen (2012+) — General Topics 21 09-08-2015 11:06 AM
Chirping from HPFP c4lvinnn Issues | Warranty | Recalls / TSB 12 05-25-2015 03:21 PM
Chirping Poll Wilsonk227 BRZ First-Gen (2012+) — General Topics 16 04-18-2014 05:28 PM
TSB Chirping ngabdala Issues | Warranty | Recalls / TSB 10 11-04-2012 10:04 PM
TSB for Chirping mankarn86 Scion FR-S / Toyota 86 GT86 General Forum 1 09-28-2012 05:09 PM
