Old 03-12-2019, 11:53 PM   #29
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by jaseow View Post
Hmm.. consensus seems to say change the battery. Should I just change it then even though 2 different places tested it and said it was fine ?
Not entirely convinced though as it starts up fine 9 out of 10 times its just that 1 extended crank that happens ever so occasionally that eats me up
I'd check the alternator first. May not be doing a good job of keeping the battery charged.
Your first post about the place that tested and checked the battery you said it was at 12.6v which is actually on the low side for a charged battery. It should be about 13.3 at full charge.
Old 03-12-2019, 11:55 PM   #30
humfrz
Usually a battery shop will want to sell you a new battery IF your old battery shows signs of age or weakness.
Is the battery presently in your car, large enough (CCA - Cold Cranking Amps) to adequately run your car? Maybe someone put a cheapo, under rated one, in your car?
Personally, I spent too damn many years with old, weak batteries and jumper cables on the front seat, to put up with a flaky battery. Batteries are "one strike and you are out" with me anymore. Maybe it's because my days of push starting a car are over (hell, I can hardly get out of one these days).
humfrz
Ultramaroon (03-13-2019)
Old 03-13-2019, 12:06 AM   #31
jaseow
Drives: 2012 Toyota 86
Thats why I was surprised when the guy told me to save my money as my battery was still ok. Thought he would be glad to sell me a battery.
The battery I have in the vehicle atm is the one recommended on this website :
https://www.batteriesplus.com.au/toyota-fittment-guide/
Exide Extreme X55D23DMF 650 CCA which should be plenty considering the stock battery is 440 CCA ?
jaseow is offline   Reply With Quote
Old 03-13-2019, 12:07 AM   #32
jaseow
Hmm maybe.. the place that did the 2nd test yesterday when I was about to buy a new battery showed a 12.8V rating
Old 03-13-2019, 12:15 AM   #33
Ultramaroon
not playing cards
Ultramaroon's Avatar
Thats exactly how I feel. Not major issue but im obsessing over it and its eating me
Already did the battery check and load test at 2 different places and both said battery was good
It would kill me too. I agree that it's likely something minor.
Old 03-13-2019, 12:16 AM   #34
humfrz
Well, hmmm... IF the battery is of the proper size and is healthy, as ol @NoHaveMSG pointed out, maybe it's time to check the alternator.
A quick & dirty test is shown here:
https://www.aa1car.com/library/battery_runs_down.htm
humfrz
Old 03-13-2019, 12:17 AM   #35
Ultramaroon
not playing cards
Does that extended crank feel weak, or strong as ever? I don't think it's the battery but I'm ready to eat crow.
Old 03-13-2019, 12:19 AM   #36
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I guess I should elaborate a little more and I am a bit too lazy to search it right now. Most 12v batteries are in the 12.6-13.3v range when fully charged. If the car had been running for any amount of time when checked the voltage should be up around 13. Though if he had load tested it before it could have pulled off the residual charge, though 12.6 is on the low end of that.
Old 03-13-2019, 12:20 AM   #37
humfrz
Only when the alternator is charging it - right ?? -
humfrz
Old 03-13-2019, 12:22 AM   #38
Ultramaroon
not playing cards
humfrz
13.8-14.2-ish
humfrz (03-13-2019)
Old 03-13-2019, 12:22 AM   #39
jaseow
Crank feels the same it just goes on for a few seconds longer before the engine actually comes to live
Old 03-13-2019, 12:24 AM   #40
Ultramaroon
not playing cards
I dunno, man. Grrrr....
Old 03-13-2019, 12:27 AM   #41
humfrz
This is what I go by:
"Battery Voltage and State of Charge:
12.66v . . . . . . . . . . 100%
12.45v . . . . . . . . . . 75%
12.24v . . . . . . . . . . 50%
12.06v . . . . . . . . . . 25%
11.89v . . . . . . . . . . 0%
(NOTE: these readings are at 80 degrees F. Battery voltage readings will drop with temperature roughly 0.01 volts for every 10 degrees F.)
(At 30 degrees F. a fully charged battery will measure about 12.588 volts, and at zero degrees F it will measure about 12.516 volts.)
CHECK BATTERY CHARGING VOLTAGE
After charging the battery or jump starting the car, connect the voltmeter to the battery the same as before and not the charging voltage. A charging system that is operating normally should produce about 13.8 to 14.3 or more volts at idle. If the charging voltage is less than 13.0 volts, the alternator is not putting out enough voltage and current to keep the battery charged."
End of quote.
(I scraped that off the Internet, so it must be true - )
humfrz
NoHaveMSG (03-13-2019)
Old 03-13-2019, 01:50 AM   #42
jaseow
Anyone know if I can buy a new battery to give it a shot, and the problem still persists, if I swap back the current battery and leave the newly bought battery aside for when the current one actually dies. Will it maintain its charge if it is stored away or will it slowly trickle away after having been used for a short period of time even though it is not connected to anything ?
I figure the battery is worth a shot and even if it isnt the battery Ill have a spare for the future ? But only if it will maintain its charge for future use
Long crank startup itzaustin Issues | Warranty | Recalls / TSB 12 03-23-2019 06:25 PM
Occasional high pitched squeak Midjetv8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-28-2016 07:00 AM
RPM occasional drop with AC on Dboe Issues | Warranty | Recalls / TSB 5 08-15-2014 05:03 PM
Best kit for occasional track usage yomny Forced Induction 14 02-06-2014 08:10 AM
a lot of people like sports cars for looks and the occasional WOT autobrz Other Vehicles & General Automotive Discussions 4 09-17-2013 02:35 PM
