Old 05-11-2020, 05:17 PM   #29
86driftcar
86driftcar's Avatar
Originally Posted by jflogerzi View Post
I would recommend this idler pulley
Dorman 419-610 Idler Pulley https://www.amazon.com/dp/B003QVIXYU...p_mob_ap_share
Belt I use
Gates K061015 Multi V-Groove Belt https://www.amazon.com/dp/B000C2YCXM...p_mob_ap_share
Hey I just wanted to keep you updated. I went ahead with the belt and pulley you suggested. It seems to have fixed the squeaking issue so far and I also feel the car is alot more responsive. Im slipping tire and the rear comes lose in certain gears & RPMs where it wasnt before. I definitely feel more response from the car.
Here is where it gets tricky - If I was previously using the larger belt which was designed for a 75mm pulley - Is it possible my belt was slipping this whole time because I ran the 69mm pulley instead? Ever since my Supercharger instal & tune I've been running the Sprintex original belt on the 69mm pulley. Is it possible that now with a tighter/smaller belt my car needs a revision tune??
I'm so confused lol
86driftcar is offline   Reply With Quote
Old 05-11-2020, 09:08 PM   #30
86TOYO2k17
Drives: 2017 toyota 86
I'm so confused lol
Possibly, but probably not, I bet it got worse over time, so wasn’t as bad when initially tuned and now worse, you might have been running rich with the slippage. Check your AFR under boost, and make sure IAM isn’t dropping. Tune should be able to compensate for minor boost changes. Could always send a log to your tuner and tell him what you did.
Old 05-11-2020, 09:17 PM   #31
jflogerzi
jflogerzi's Avatar
Would not hurt to send a log.. but check the above. Definitely look at these before you go WOT as you don't want to be lean now .
2013 Series 10 FRS #553
Sprintex 210 Supercharger + Intercooler Kit R2RO Engine, Exhaust, Bolt-Ons 24 09-03-2018 09:46 PM
Sprintex Supercharger Jakebowles Engine, Exhaust, Bolt-Ons 1 08-11-2016 02:24 PM
Sprintex Supercharger Group BUY! Xero-Limit Groupbuys 44 02-14-2015 03:13 PM
RMS Sprintex Supercharger for sale Ryan86 AFRICA 5 12-16-2014 12:59 PM
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
