Old 02-14-2019, 01:04 PM   #29
CoolHandMoss
Drives: 2013 FRS
I like the 949 lug nuts. I have used them on my twins and Miatas before that. Very good quality parts. They hold up to long term use better than some others that I have used.
CoolHandMoss is offline   Reply With Quote
The Following User Says Thank You to CoolHandMoss For This Useful Post:
Lincoln Logs (02-15-2019)
Old 02-14-2019, 05:04 PM   #30
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by HaXx View Post
I just ordered enkeis from tire rack and it includes 20 "required lugnut for vehicle" at no charge. Any idea if they are tire rack brand? Base enkei lugs? I'm planing on using them unless you guys object.
Whatever you get from tire rack will be quality, go ahead and throw them on!
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
HaXx (02-14-2019)
Old 02-14-2019, 05:57 PM   #31
86MLR
86MLR's Avatar
The RS05RR that I got for my STI came with Rays steel nuts.
That was in AU though, you may get something different.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
HaXx (02-14-2019)
Old 02-15-2019, 06:58 AM   #32
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by Yoshoobaroo View Post
The weight argument is moot unless your wheels weigh like 16lbs. You'll never notice the difference.
That said, closed end steel. I tried open ended but I got tired real quick of my wheels getting coated in rusty juice whenever it rains. Got a set of Muteki SR35 in black.
What if they weigh 6lbs? The point is to save weight where you can. Any way to eke out a little bit better gas mileage is worth it to me.
Originally Posted by Mr.ac View Post
Weight savings? Ha!! Not sure if that's part of the marketing scheme, or you really think less than 1lb is going to make a difference.
If that's the case, do you take a shit every time you go out to drive? Cause you can save a pound or two.
Besides it's not like you are in a high stakes race where every gram counts.
Eh. To me that's on the level as what old ricers would love to say.
Have you read Anthony's thread? you save weight where you can. Lots of things less than 1 pound can add up. As long as they are quality from a good company they'll be fine.
You'll get some random steel lugnuts. They'll work. So will your oem ones since subaru uses acorn lug nuts which are the same you need to use for most aftermarket wheels.
The Following User Says Thank You to why? For This Useful Post:
HaXx (02-15-2019)
Old 02-15-2019, 09:36 AM   #33
Yoshoobaroo
TRACKBREAD
What? Really?
The stock ones weigh 0.8lbs total. Even if you made them out of depleted uranium they'd weigh under 2lbs. You'd need a material half the density of the core of the sun to make them total 6lbs! Please let us know when you find these lug nuts, we can finally crack nuclear fusion when you do!
You'd better shave your new tires down to 25% before putting them on, there's way more weight savings there!
Old 02-15-2019, 11:42 AM   #34
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Either open ended or closed end aluminum lug nuts are the best. In the event you cross thread, you'll lose a cheap lug nut instead of a stud. There are no issues using aluminum lug nuts on track either, I've done it for years and years with my Miata. Lots of misinformation in this thread.
Lincoln Logs is offline   Reply With Quote
Old 02-15-2019, 07:16 PM   #35
mooshu47
mooshu47's Avatar
Drives: 2015 BRZ Limited
Speaking of lug nuts: I bought a set of these:
https://thmotorsports.com/487340-kic...t-r40-lug-nuts
And I can't find any end caps for them. The ones for the iconix lugs don't fit these (the threads are the right size but the cap part is too big to fit into the lug). Anyone know where to get some? Or something else I could use? Bubble gum?
mooshu47 is offline   Reply With Quote
Old 02-15-2019, 08:13 PM   #36
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Things ricers say for $1000 Alex.
Come on dude. I'll take it as a joke. Cause it really reads as a joke.
Old 02-15-2019, 09:20 PM   #37
new2subaru
Weight Weenie
Drives: 15 FR-S
Old 02-19-2019, 01:33 AM   #38
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
I personally use steel, closed end (black mcgard tuner lugs). My friends use Work/RAYS aluminum lugs which work just fine for them as well. General rule is that aluminum are fine and just as strong for most purposes, just don't use power tools on them.
While OEM have the correct taper for aftermarket wheels (worked just fine with my Enkei for a few days), they don't look as nice as aftermarkets, are sunk pretty far into most aftermarket wheels (aesthetics again), and the chrome finish corroded.
"Why must everything that is broken be fixed?"
GhostRai is offline   Reply With Quote
Old 02-19-2019, 01:56 PM   #39
why?
why?'s Avatar
Drives: series.blue
Aww, poor baby can't read.
Originally Posted by Anthony View Post
http://www.ft86club.com/forums/showp...&postcount=147
Lug nuts (x5)
0.590lbs | 267.6g - Muteki SR48 (Source)
0.440lbs | 199.5g - Muteki SR35 (Source)
0.410lbs | 185.9g - Gorilla Chrome Tuner (Source)
0.275lbs | 124.7g - OEM (Source) (Additional Source)
0.250lbs | 113.3g - Rays Engineering (Source)
0.250lbs | 113.3g - VMS Racing (Source)
0.202lbs | 092.0g - CSG aluminum (Source)
0.144lbs | 065.3g - Gorilla forged aluminum (Source)
Looks like a difference to me. Next you are going to say 2751 and 2280 are the exact same weight, right?
What? Really?
reread the quote and the conversation. We weren't talking about the lug nuts.
Old 02-19-2019, 02:47 PM   #40
ZionsWrath
Thanks
ZionsWrath's Avatar
Depends on your application. With frequent wheel changes and/or tracking I really loved when I switched to ARP extended studs and muteki sr48 (open end lugs). No issues trying to start the threads with the tiny Subaru lugs through the deeper holes of my wider wheels to the subaru short stud. Also I felt a lot more comfortable using the impact on the ARP studs than OEM.
That said if I only street drove the car and the wheels came off only once or twice a year I would probably prefer closed lug nut.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Takumi788 (02-19-2019)
Old 02-20-2019, 11:32 AM   #41
Yoshoobaroo
TRACKBREAD
Ooooohhhhhhhhh
Old 02-20-2019, 07:49 PM   #42
HaXx
Drives: jrsc_brz
Will open end really cause it to rust that bad?
HaXx is offline   Reply With Quote
FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve neilvosko Wheels and Tires 14 06-18-2018 10:47 PM
Lets talk lug nuts Ibanezboy21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-23-2014 04:42 PM
Talk me into, or out of, a Mac Chimpo Off-Topic Lounge [WARNING: NO POLITICS] 49 06-18-2013 02:37 PM
Car talk calis5nest FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-02-2013 03:04 PM
BMW talk RaceR Other Vehicles & General Automotive Discussions 101 01-15-2013 12:32 PM
