Old 02-08-2019, 07:45 AM   #29
zagato4r
Drives: 2020 BRZ TS, Alfa Romeo 4C
I am experiencing the same problem with a 2019 Series Gray. At 500 miles it started making the clunking noise at lower speeds on rough streets. The clunking is very noticeable in below freezing temperatures and seems to disappear as temperatures rise. I have had the car in two different Subaru dealers five times, with no solution. On the third visit, they used Subaru's "chassis ears" to try to locate the source of the clunking. On the fourth visit, they replaced the right rear shock, which made no difference. On the last visit, they put the car on the alignment rack and loosened and re-torqued all rear suspension fasteners, this made no difference. I had a 2014 BRZ Limited for 55,000 miles with zero issues, so this problem is very frustrating. I am hoping someone can find a solution or I will need to move to a warmer climate.
zagato4r is offline   Reply With Quote
Old 02-11-2019, 06:12 PM   #30
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Dang. I hope this isn't something that just comes with the cold weather. The dealer is looking at the car tomorrow and I will report back with what they find.
MotoX16 is offline   Reply With Quote
The Following 2 Users Say Thank You to MotoX16 For This Useful Post:
Tcoat (02-12-2019), Ultramaroon (02-12-2019)
Old 02-11-2019, 06:38 PM   #31
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
If you have the oem audio system or added sub in the back, they get lose. I have a clunk whenever I brake hard.
Old 02-12-2019, 10:30 AM   #32
MotoX16
MotoX16's Avatar
Stock audio system, stock everything. I removed everything from the trunk (tools/spare) and folded down the seats and the noise is still there.
Old 02-12-2019, 05:56 PM   #33
MotoX16
MotoX16's Avatar
Heard back from the dealer today. They inspected/tightened all suspension components but didn't find any problems there. They confirmed there was a noise and believe its coming from the struts although there were no visible leaks. They ordered me a set of new rear struts and top hats but Subaru has them listed on backorder until April. Hopefully they come in a bit earlier but I'll update you guys when they do.
Old 02-12-2019, 07:10 PM   #34
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
errr....dont think it's the strut at all. That's just blind guessing, aka I don't know what to do so i'm gonna replace this thing.
noise from the rear if it's clunk, it's gonna be one of the bushing/brake area/diff & sub frame area. cuz nothing else moves.
You also said noise goes away when it's warm. meaning it's likely small clearance issue
find someone else who has a twin & let him drive it while you sit in the back, maybe that will help you locate where it's from.
Old 02-13-2019, 04:41 PM   #35
MotoX16
MotoX16's Avatar
I'm not 100% sold that its a strut either. But hey its under warranty so I wont complain about free parts.
I don't think I said it goes away when its warm. Hard to tell during winter but whether its -20 or 20 it doesn't make a difference.
Old 02-13-2019, 06:17 PM   #36
Silverz
Drives: Black frs
Exact same thing the dealer told me. But mine was out of warrantee and I wasn’t paying dealer prices for struts. Also said struts were on back order. That must be the standard operating procedure when they can’t find problem. Lol
Silverz is offline   Reply With Quote
Old 02-13-2019, 07:05 PM   #37
Ultramaroon
not playing cards
Ultramaroon's Avatar
Not joking. Squat down next to one of the rear wheels, grab hold, and shake the shit out of it in sync with the frequency it wants to bounce.
You will find the clunk.
chaoskaze (02-13-2019)
Old 02-13-2019, 07:22 PM   #38
Or. It was a strut and they just don't have a huge stock pile of them.
Old 02-13-2019, 09:44 PM   #39
humfrz
Did you learn that trick from Bubba??
humfrz
Ultramaroon (02-14-2019)
Old 02-13-2019, 10:31 PM   #40
Ultramaroon
not playing cards
Yup
humfrz (02-13-2019)
Old 02-23-2019, 04:25 PM   #41
zagato4r
I just got my 2019 Series Gray back from the sixth dealer visit. The latest attempt at curing the rear suspension clunking noise lasted 4 days with no resolution. On this visit they disconnected the rear sway bar, swapped the shocks from side to side (one of which was replaced by the previous dealer who looked at the car), retorqued everything and took multiple test drives with two techs. The next step is an appointment with a Subaru field engineer, because the dealer is baffled. This has become a major frustration with only 1600 miles on the car.
Old 03-02-2022, 09:17 AM   #42
MotoX16
MotoX16's Avatar
I'll post a quick update, not sure how much it will help though. I never definitively found the problem. The dealer replacing the rear struts did not help. Unfortunately I did a couple mods on the same day, way back when, and haven't heard any noises since. I'm thinking it was either the rce yellow springs that fixed it, or the whiteline subframe bushings. The rear end felt a lot more solid after those and no more clunks.
Very possibly could have been something else. Having the rear suspension components loosen and the reseated/torqued might have been all it needed. Or maybe it just went away with time. Hard to tell for sure
Hope that can maybe help someone else
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
Clunking noise when tapping on gas at low rpm jeschris45 Engine, Exhaust, Transmission 2 03-05-2018 11:04 PM
ISC Control Arm Clunking and Noise megamarines Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-12-2016 04:28 AM
Tire Clunking Noise darko Issues | Warranty | Recalls / TSB 5 04-01-2016 03:57 PM
Clunking Noise After LCA Install Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-06-2015 04:24 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 05:02 PM
