Old 01-21-2019, 05:46 PM   #29
Originally Posted by DarkPira7e View Post
I think as a preventative measure, it's not the worst thing to consider on a car that's over 80k. Better to have peace of mind, than wondering why your coolant temp is pegging red. Hell if I had the money, I'd replace more an just eat labor all day. Partial labor is better than full labor!
EDIT:: My opinion may stem from owning several E36 BMWs. I won't take back what I said though
Pretty model specific preemptive maintenance though. I would not worry about it on these cars but every time I opened the engine on my old Talon I just changed the water pump because they were pretty much always about 5 more revolutions away from falling apart.
Old 01-21-2019, 06:29 PM   #30
neo95
Update part is on back order and it's about 2-3 weeks to get in and then schedule for repair. The advisor already has dealt with 2 frs on the recall. The advisor willing to work on charging part only for the TOB.
Sent from my PH-1 using Tapatalk
neo95 is offline   Reply With Quote
The Following User Says Thank You to neo95 For This Useful Post:
humfrz (01-22-2019)
Old 01-21-2019, 07:11 PM   #31
humfrz
Originally Posted by neo95 View Post
Yeah I haven't really heard of any issues with the water pump. Just looks to see what would be good to replace while engine out. Already did the spark plugs. I was trying to see on the PDF for the repair manual if shows if the water pump has to come out. I did notice transmission fluid change . Biggest thing is the throw out bearing if they can do for part cost only
Oh, I can understand replacement of the TOB. But, replacing other things would just be trying to second guess what will go wrong.
I recall back-in-the-day, I drove this 1948 Chev for over 10 years. My main parts supplier was the local junk yard. So, when something went out (like a fuel pump) I would pull two of them off junk cars. One I would replace the one that had gone bad and I kept the other one in the trunk as a "spare".
Guess what? The same thing never went bad the second time -
In my basement I still have a used fuel pump for a stovebolt 6 chevy engine, if you are interested -
humfrz
gravitylover (01-21-2019)
Old 01-21-2019, 11:30 PM   #32
humfrz
too bad.
In my 60 years of driving cars, I've never had a water pump go bad -
However, I've never owned or driven a BMW -
humfrz
Old 01-21-2019, 11:59 PM   #33
Dake
Dake's Avatar
I think Bimmers get new water pumps with every other oil change.
Dake is offline   Reply With Quote
Old 01-22-2019, 02:23 AM   #34
humfrz
Water pumps, bah-humbug.
The aftermarket and tuners sure did complicate the cooling of the internal combustion gasoline engine.
With the exception of the first year or two, during the 18 years that Ford produced the Model T, Ford didn't install a water pump for the engine. They discovered it ran better without a water pump. Why didn't it overheat? Hint, look at the size of the radiator.
Yes, it IS my med time -
humfrz
Old 01-22-2019, 09:01 AM   #35
too bad.
humfrz
The only one I had go on an old car was the 58 Nomad. And it was spectacular!
Driving down the highway and it started to squeal. Before I could get pulled over it went BANG GRIND BANG. The bearing had let go and the shaft wobbled which totally destroyed the impeller. The whole shaft then shot forward about 6 inches. The problem with that was the rad was only 4 inches away. It was a mess. Unfortunately there was no running to the local wreckers for 58 Chev parts in 1983 and since the internet was still a dream it meant hours on the phone looking for parts. Managed to get a pump from a dealer with old stock but had to have the rad re-cored which took some time. I was very aware of water pumps from that day on.
humfrz (01-22-2019), swfrs (01-23-2019)
Old 01-22-2019, 11:42 AM   #36
gravitylover
I had the water pump give up on my 1960 Willys CJ5 on a Sunday afternoon when I was still 40 miles from home. I pulled into a Chinese restaurant, turned it off and heard a pop then the coolant started draining out the front of the motor. What a mess. I pulled the pump out, took about 20 minutes because I had never done one before, then I went next door to the very conveniently placed Napa and they had a reman in stock. 20 minutes later it was all buttoned up so we ate lunch and continued on our way. It was one of those no harm no foul things but there was all sorts of room in that engine compartment and that old Dauntless 225 V6 was a piece of cake to work on.
Old 01-22-2019, 12:34 PM   #37
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I once took a wheel off and put it back on again.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Dadhawk (01-22-2019)
Old 01-22-2019, 12:36 PM   #38
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by nos145 View Post
kool. ill keep my sources to myself.
so. assuming we have one?
For free? It's just weird. I'd want someone who knows what they're doing. The number of built and blown motors is high.
Old 01-22-2019, 12:47 PM   #39
EAGLE5
Dismember
EAGLE5's Avatar
Old 01-22-2019, 01:16 PM   #40
Dake
Dake's Avatar
Missed the chance to take pics with the heads off, but still got some with the motor out, since I'm having them do the clutch and TOB while it's apart.
Still a fair amount of life left in the old clutch - that's only 50'ish thousand miles.
I'm a little annoyed that they buggered some of the mating surface up on the motor-side (the timing chain cover is clean). Comes from using steel prytools on aluminum. Fortunately, nothing cuts clear across the surface, so I'm thinking it will still get a good seal.
If it does leak though, I've brought it up with the service dept, so there's a record of it.
The Following 4 Users Say Thank You to Dake For This Useful Post:
DarkPira7e (01-22-2019), humfrz (01-22-2019), slizoth (02-18-2019), swfrs (01-23-2019)
Old 01-22-2019, 01:47 PM   #41
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm extremely surprised they let you under the lift, typically that's a crazy insurance risk they wouldn't consider - very cool. Good that you caught the damage, even if it is slight. Last thing you'd want is an issue that they could readily deny and place the damage on your shoulders. I've never seen the FA20 on a stand before, looks anemic and out of place with a timing chain instead of the belt assembly..
Old 01-22-2019, 01:56 PM   #42
MikeMont
Drives: Black 2013 FRS
I'm due for a trans oil change, among a slew of other things. Just to clarify, do they drain/ refill the trans oil for this recall procedure?
MikeMont is offline   Reply With Quote
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 12:09 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 09:44 PM
