Old 02-27-2019, 09:29 PM   #29
Originally Posted by Turbo View Post
Understood.
Mike - what have you done to combat this issue with your track car? You're running a boosted setup with similar HP to me in your '86.
I have had zero problems to date in mine -- but I also haven't driven any tracks with long, left hand sweepers. I will be driving a few new tracks this coming season, and I'd rather solve this issue before running into it.
I do have an idea - anyone have a picture of the top of an FRS/BRZ fuel tank out of the car I can take a look at??
I've not yet found an optimal solution yet. I run hydramat, and literally fill up my tank to the brim before each outing.
Old 04-20-2021, 11:19 AM   #30
dgilliesau
Drives: Blue BRZ
You sure it's installed correctly? No problems with your fuel pump?
I'm boosted and can practically run down to vapours without issue. I see close to 2G's cornering and consistently hit 1.4G's braking on the track.
How have you achieved this? I installed the flap which improved starvation on th Amaroo circuit with 2 consecutive left handers, but on the Sydney Motorsport Park I starve halfway down the straight after the 2 long left handers that lead onto the straight. It's like having a rev limiter at 6000rpm in 5th.
Now looking at what to do next.... Ideas?
dgilliesau is offline   Reply With Quote
Old 01-17-2022, 09:35 AM   #31
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
I've a new 2022 BRZ and am wondering if in 2020 or 2022 they have addressed the fuel starvation issues or is still the same problem/same fuel pickup design?
I've had to run the tank full in my STI. I had some foam in the tank at one point, that helped. Then some of it disintegrated and made a big mess.
I've thought of getting the Hydramat.
It seems only one person mentioned it and it was not a solution? I'm surprised.
If I must do a surge tank it sure as hell won't be in the engine compartment and I'll put in a fireproof bulkhead. First, I'll think hard about a manually actuated transfer pump for the right side.
Scargod is offline   Reply With Quote
DIY : Draining the gas tank - Methods to empty fuel tank Mermoz DIY (Do-It-Yourself) Guides 13 10-09-2025 03:56 PM
JUN GT SURGE TANK FOR FT86/BRZ scubie.brz Engine, Exhaust, Transmission 60 11-23-2020 08:48 PM
Radium Engineering developing dual in-tank pump hanger slicktop Forced Induction 18 06-13-2017 03:42 AM
SARD Surge Tank Kit w/ ITB from TAS 2017 mav1178 Engine, Exhaust, Transmission 50 05-12-2017 11:50 PM
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion Xero-Limit Engine, Exhaust, Transmission 42 04-27-2017 10:16 PM
