| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
TRACKBREAD
| The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | Evil Rocky (06-01-2020), ThatYeti (06-01-2020) |
#30 |
Do you think the extra cutting makes a difference? Or would the air still stream through without it being cut? Maybe the smaller exit would create a vacuum?
#31 |
TRACKBREAD
#32 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I will likely do what you did, but keep the clip parts and cut in between.
#33 |
So I got the fender garnishes. I am cutting out the spots between the clips from behind, but not the black trim part. Just the backing behind it. After that I am drilling multiple holes along the angle lines of the black trim part. Not sure it will be enough open space , but I want to go subtle first before I go big and cut it all out.
#34 | |
Drives: 2014 Subaru Forester
#35 | |
Be Kind
Drives: 2020 86
Would drilling a bunch of holes so it's essentially a perforated fender area allow the heat to be reduced and retain the factory clip locations without ruining the cooling abilities of the rest of the cooling system? I think you'd need multiple temperature probes in a few different locations around the engine bay and a few test drives or a huge dyno styled fan to test all of this....
#36 |
ProCrastinationConsultant
also would require airflow sensors to determine if it's helping or hurting aerodynamics as well.
#37 |
Here is what did. Still have stock ones in case, but went for a drive. When I parked the car in the garage the heat is pouring out of the fender garnish. Have no idea if it works at speed. It’s good for now, not perfect but I like it. All clips were used and new 3m tape. Let me know what you think.
https://imgur.com/rm7dJoZ https://imgur.com/MTotgde Last edited by Ernest72; 06-03-2020 at 07:55 PM. |
#38 |
Drives: 2013 frs base
Garnish vents
I trimmed down cast aluminum registers to make my garnish vents. This allowed a large openings in the fenders to let air out of the engine compartment.
#39 |
Nice job, but I would get more of a grill with smaller holes. I think it will look better and still allow plenty of air flow.
#40 |
Holes from a distance
I'm sure there is a better option out there but these were less than $20 each.
#41 |
Drives: toyota gt86 1st edition
damn thats function over form for sure!
| The Following 2 Users Say Thank You to maicolp For This Useful Post: | DarkPira7e (08-25-2020), Wally86 (08-25-2020) |
| Tags |
| diy, fender, vent |
| Vented BRZ Fender Trim! | zkv476 | DIY (Do-It-Yourself) Guides | 121 | 11-05-2018 12:10 PM |
| WTB: BRZ fender trim | 3ananaPie | Want-To-Buy Requests | 0 | 12-08-2015 07:29 AM |
| trying to understand 'supra' TRD style vented fender | Top-Secret | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-04-2015 09:18 PM |
| WTB: BRZ Fender Trim | technoid | Exterior Parts (Aero, Lighting, Etc.) | 0 | 07-13-2014 12:57 AM |
| Fender Trim, What do you have? | joergasm | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-10-2012 03:18 AM |
