Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 |
Drives: '15 BRZ, Vortech supercharger
Yea, let us know if DW can check pump function.
#30 |
So another little suspicion I have is that the top of my fuel pump was not properly seated inside the housing. The Deatschwerks install kit comes with 3 o-rings that go on the pump outlet nipple, which makes a seal when you shove it up into the housing. When i took mine apart the first time, the pump just kind of fell out. When I put it back together yesterday, I lubed up the o-rings with some petroleum jelly and really push it into the housing to make sure it seated properly.
I'm going to try to find a replacement c-clip before putting it back together then I'll report back if it changed anything. |
The Following User Says Thank You to Whoodoo For This Useful Post: | DustinS (09-17-2018) |
#31 |
Drives: '17 BRZ PP, old Legacy SSs and SVXs
I found my problem.
![]() The video I used as a installation guide for the pump used the "3 O-ring" method instead of reusing the spacer. The result is that over time the o-rings pushed out of the housing and caused an internal leak. This resulted in both the siphon not working (9 gallon empty) and an occasional hard start issue. I have reinstalled the spacer (with a slit to accommodate the DW300c ridges) and 2 new o-rings. All seems well so far. |
The Following User Says Thank You to PhyrraM For This Useful Post: | bcj (09-23-2018) |
#32 |
yea, for now I think we can point toward an improper seal at top of the pump. Thanks for helping me figure this out!
#33 | |
Contract? /人◕ ‿‿ ◕人\
The Following User Says Thank You to soulreapersteve For This Useful Post: | Ultramaroon (09-24-2018) |
Out of fuel with 2 gallons in the tank | Simisimi | Issues | Warranty | Recalls / TSB | 31 | 06-18-2015 03:30 PM |
