Old 07-05-2018, 01:27 AM   #29
humfrz
Originally Posted by celek View Post
Piston is designed for over 1 million cycles. The contact surface is solid steel bearing axial load surpasses force needed to depress a clutch by almost 3x. It won’t end up collapsing like factory.
Looks to be an interesting concept.
* does the bearing make constant contact with the pressure plate fingers?
* how is the bearing lubricated?
Thanks,
humfrz
churchx (07-05-2018)
Old 07-05-2018, 01:01 PM   #30
celek
Resident Gear Head
celek's Avatar
Thanks,
humfrz
With no pressure the piston just touches the fingers not constant pressure the bearing is sealed and replaceable.
The entire unit is rebuildable at a fraction of original cost. Seals and base are rated at over 1 million cycles.
Im beating the heck out of it now trying to make it fail purposely riding the clutch shifting more than needed randomly pumping the pedal while driving let the car idle for a few hours sit at traffic lights holding the clutch in. ect..., but the amount of research and time is spent researching and designing parts I want this to be the last time anyone has to replace it.
celek is offline   Reply With Quote
The Following 6 Users Say Thank You to celek For This Useful Post:
bcj (07-05-2018), Calum (03-24-2019), humfrz (07-05-2018), TofuJoe (07-05-2018), Trefoil (08-30-2018), Ultramaroon (07-05-2018)
Old 07-05-2018, 03:06 PM   #31
Ultramaroon
not playing cards
Ultramaroon's Avatar
How does Tilton allow for co-axial tolerance?
Old 07-05-2018, 07:50 PM   #32
fika84
fika84's Avatar
@celek so this is what's been keeping you from the ITB's??? COME ON! Just kidding, this is badass dude!!
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Old 07-06-2018, 11:41 AM   #33
celek
Resident Gear Head
celek's Avatar
Are you referring to the movement of the rotation of the contact surface? If that is the question its not Tiltons part it is re-engineered the only part that is Tiltons is the base and seals.
Piston Bearing and contact surface is not an off the self part from Tilton.
Old 07-06-2018, 02:58 PM   #34
Ultramaroon
not playing cards
Wow! I'm beginning to understand. You really did go all out.
To rephrase my question, is there allowance for the bearing and contact surface to float into position coaxial to the pressure plate under load?
humfrz (07-06-2018)
Old 07-09-2018, 09:40 AM   #35
celek
Resident Gear Head
celek's Avatar
entire unit is dead centered to the clutch. if there was any movement it can slide on the contact surface and there is movement of the piston in any direction X Y Z axis inside the seals it can shift around.
The Following User Says Thank You to celek For This Useful Post:
Ultramaroon (07-09-2018)
Old 07-09-2018, 11:25 AM   #36
highway7
Drives: FRS 2013
Nice!
highway7 is offline   Reply With Quote
Old 07-09-2018, 11:33 AM   #37
HawaiianMike
Drives: 2015 Brz Limited
Definitely looking forward to this as I'm always paranoid about my clutch system going bad (which I think it is).
HawaiianMike is offline   Reply With Quote
Old 07-09-2018, 11:52 AM   #38
FRS Justin
Drives: 2013 Asphalt FRS
How will this work with dual and triple disc setups with high pressure plate ratings??
looks awesome
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 07-09-2018, 02:21 PM   #39
celek
Resident Gear Head
celek's Avatar
looks awesome
Depends If the Height of the pressure plate changes from factory height.
I have a little bit of give in the bearing to support a taller Pressure plate but if it is too tall I will have to custom one off the base to adjust the height. Unlike the original fork which has full movement this piston can only move so much before falling out. So it has to be engineered within the tolerance of space and available movement of the clutch its self.
As for heavier plate ratings no problems at all. Its hydraulic.
FRS Justin (07-09-2018)
Old 07-10-2018, 04:35 PM   #40
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I built a setup like this back when i had a faceplated tremec trans behind an fa20. Much better feel than a fork and way more reliable (bent forks). Solid setup, nice work
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
celek (07-10-2018), Sportsguy83 (07-12-2018)
Old 07-10-2018, 05:41 PM   #41
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I've seen these things floating around for a while and was curious if they were/are worth the outlay. Subbed
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-11-2018, 12:19 AM   #42
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I aint gonna pay $600, yeah nope! But I'll pay $200! Now thats a good deal.
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
celek (07-11-2018)
failure, hydraulic conversion, throw out bearing, tob
TOM'S 2013 JDM Converted for USDM DOT/SAE Approved LED Tail Lights in RED Lense willfong Exterior Parts (Aero, Lighting, Etc.) 0 01-22-2017 05:31 PM
Push Button Install (for BRZ Limited/10 Series/Converted FR-S or BRZ Premium) brz_star21 DIY (Do-It-Yourself) Guides 10 12-21-2016 03:41 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
Hydraulic Handbrake ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-20-2015 11:17 PM
