Old 06-13-2018, 09:50 PM   #29
steve99
Originally Posted by PetrolioBenzina View Post
I'd like to try that tune! Totally stock 17 86.
are you on stock oft tune ?? which revision v4 ?
Old 06-14-2018, 03:08 AM   #30
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Originally Posted by tomm.brz View Post
I'm sorry i created confusion in the op's mind. He created this thread because of something I wrote that was somehow misleading
my car does NOT drinks like a V8 and I created confusion saying about my INSTANT consumption relevations. And i should had not do that
So, OP, don t worry you won't consume like a V8 if you change header and tune the car
The post of mine you cited, I repeat, was only to say that specifically after putting Wayne's Rom cam timings, my fuel consumption rised a bit compared to OTS cam timings, during low speed low load city driving, but gained a lot of smoothness and driveability from them
As an OP, I get your message. Your original message got me lose my sleep over it because I don't want to turn my car into a V8 drinker.
Never mind, I am cleared and can have my rest now.
Spec C Wannabe is offline   Reply With Quote
The Following User Says Thank You to Spec C Wannabe For This Useful Post:
tomm.brz (06-14-2018)
Old 06-14-2018, 03:43 AM   #31
Spec C Wannabe
If you get way worse fuel economy after installing header, cgeck your ltft if its running high like 10% or npre especially at lower. \rpm, you likely jave amd exhaust leak. Generally this wil caise o2 sensor to see fresh air so ecu tginks car is rin ing lean so ot add lots of fiel via high positive ltft.
And dont ise o2 sensor spacers when you have tune, and never put spacer or adapter in front o2 sensor, ive had seceral cars turn up from exhaist shop installs with spacer in front 02 it thows fueling way off.
Is it OK if there is a bung extension for the rear O2 Sensor?
Old 06-14-2018, 03:57 AM   #32
steve99
If its in rear 02 sensor its ok but not needed.
If its in front 02 sensors its going to stuff up the sensor reading , front 02 is the main fueling sensor
Old 06-14-2018, 05:03 AM   #33
tomm.brz
Drives: brz 2017 hksv2
Steve a question i dont find a good answer..
In aftermarket header specially on uel, what is the best position for the FRONT o2 sensor? In the single tube hole or where the tubes merge just at the end near the overpipe?
Old 06-14-2018, 06:40 AM   #34
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Closer is better. Most aftermarket makers will try to put it the same distance from the exhaust port as stock, which means single runner unless you have 4-2-1 with short primaries, which UEL's are not.
Old 06-14-2018, 06:53 AM   #35
tomm.brz
Thanks wayno, my question is that i have a HKS uel boxer spec header. The official instructions of this headee says to put A/F sensor (i guess they mean front sensor?) to the second hole near the overpipe and the o2 (i guess rear o2) to the closer singlw runner hole) and they specifically give you an extension for the grey cable that is for the front sensor to let you put the front sensor on the further hole Near the overpipe
And that is the opposite of what you are saying.. But if you think it is bettter to put the front sensor on the single runner (on my hks uel header it is on a short runner) i could try it..
Now i have the front sensor near the overpipe and actuallt my closed loop feels not so smooth, the acceleration with low throttle feels sluggish and not regular
Old 06-14-2018, 11:46 AM   #36
Wayno
Wayno's Avatar
Install in the same confirguration as factory. Primary before secondary.
Old 06-14-2018, 02:05 PM   #37
tomm.brz
I ll upload soon what hks writes. It s the opposite of what you say!
but i would be glad hks is wrong and you are right since my closed loop specially doesn t feel so great, and I m over 235 reflash on my car so I did experiment a lot
I would just like to know why HKS says so
Old 06-14-2018, 02:21 PM   #38
sandy s
Drives: 86 gt
I could see unproved fuel consumption when I installed the V2 stage 2 tune over stock. Car used a lot less fuel and ran better.
sandy s is offline   Reply With Quote
Old 06-14-2018, 02:46 PM   #39
Kodename47
Kodename47's Avatar
Drives: UK GT86
The problem is that you really don't want the main O2 feedback based on a single cylinder. I think that is more of a concern than having the distance from the valves. I run a single O2 sensor and if I had that manifold I'd bung the port in the single runner and fit the sensor in the collector.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Spuds (06-14-2018)
Old 06-14-2018, 03:12 PM   #40
tomm.brz
So that is the official instruction from hks
So the front lambda goes to near the overpipe, as kodename says. I did this way.
And actually this way makes the front lambda more close to. The exhaust holes Because of the shorter runners. The other hole on this header is on a longer runner so that would make the front lambda actually more further from the engine.
Wayne says to put on tbe single hole on the longer runner I think, against what HKs and kodename say. Who has right?
Old 06-14-2018, 04:26 PM   #41
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you read what Wayno wrote, it's not disagreeing with me. Primary O2 in a single runner is bad, end of. Some manifolds have it at the primary collector in a 4-2-1 but you want the sensor to read as many cylinders as possible.
Think about it this way, if that single cylinder happens to run much richer than one of the others, then you'll have one that is running consistently lean. If you have it in the collector then at least that is averaged out.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-14-2018, 04:37 PM   #42
tomm.brz
Well i could misunderstand but wayne said "primary before secondary" that sounded to me that he meant in front o2 in the single runner
Anyway i just will keep the front o2 as i have now then, on the collector at the end as HKS says
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune tomaszjanczak Engine, Exhaust, Transmission 15 09-25-2016 11:06 PM
How much fuel consumption difference: 1 person vs. 2 people djmm Scion FR-S / Toyota 86 GT86 General Forum 19 04-30-2014 04:33 PM
Fuel consumption figures too PuGZoR AUSTRALIA 25 02-16-2014 05:36 PM
Tyre Pressures/Fuel Consumption Vic_RSA AFRICA 11 12-11-2012 01:20 PM
Weight, fuel consumption and 0-100. Loki556 AUSTRALIA 15 07-16-2012 09:06 PM
