#29 |
The Dictater
Drives: '13 Red Scion FRS
Modern engines are designed to burn a bit of oil for the sake of longevity and mpg. Just check it every week or two and top up when it's near the low mark.
Also, always wipe your dipstick. Alsoalso, this seems familiar... http://www.ft86club.com/forums/showthread.php?t=119993 |
| The Following User Says Thank You to Spuds For This Useful Post: | Beachin86 (02-15-2018) |
#30 |
Actually I went back and looked at my order. I didn't get the SX I got the S.
There are these versions: F108: No nipple F108N: Long nipple (this is the one that I read goes past the cover) F108S: Short nipple F108SX: This one has a short nipple but is at a 90 I'm thinking I should have gotten the SX. Oh well, too late now. So, does the F108S extent past the engine cover? I really hope not, that sounds like a recipe for disaster. From your picture it looks like it is safely recessed. |
#31 | ||
Proud of BOXER
Drives: Subaru Boxer
Oh yeah, can you confirm that you are pulling the dipstick out, wiping it clean with a paper towel, then reinserting it, removing it, and taking a visual reading at that point?
Also you mentioned color a few times, the color of the oil doesn't have anything to do with the life of or "capacity" left in the oil. Quote:
| The Following User Says Thank You to Clipdat For This Useful Post: | Cole (02-15-2018) |
#32 | |
The Dictater
#34 | |||
Not sure what the benefit would be. If the metal is large enough to make it to the filter then it will get ... well.. filtered. If too small for the filter to grab it isn't causing any issue anyway.
#35 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
That was my thought. Looks like the dipstick when you initially pull it out. Still could be low though |
#36 |
#37 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
They would catch particles going past and keep them there, though wouldn't have any effect at all on aluminum, brass, bronze or gasket snot. So not much really. I did say "REALLY SERIOUS". Someone who was convinced it works gave me some. They're still in the box on a shelf. No. Wouldn't restrict flow at all.
"I gotta rock." -- Charley Brown |
#38 |
Drives: FRS 2013
I check after parking my car overnight.
Pull dipstick, wipe Insert dipstick the same way you pulled it out (Otherwise the dipstick will not show correct mark) Wait a second or 2 Pull out dipstick, making sure not to allow oil to move up dipstick Read the side of dipstick with lower reading that the entire width is covered There will be some slight oil along the edge of the dipstick due to dipstick going in and out If there is oil in the 'low oil' hole then you at least have oil at the min mark |
| What can I stick this onto... | GhostRai | Other Vehicles & General Automotive Discussions | 28 | 07-05-2017 06:24 PM |
| dip stick dilemma | notout86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 04-15-2015 05:52 AM |
| I should stick to my bicycle | SeanBlader | Northern California | 1 | 11-18-2014 12:09 AM |
| RPM stick between 3.5 - 4.5 | Realm | Engine, Exhaust, Transmission | 6 | 09-18-2012 01:10 PM |
| Car Name; Reason why FT-86 won't stick | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 07-17-2011 12:52 PM |
