#29 |
Only users lose drugs.
Drives: All the time
LWFW will make the car a little more prone to stalling if your clutch technique isn't perfect. This can make stop and go driving even more tedious than it already is. That said, it won't cause clutch shudder (contaminated friction surfaces or warping causes that). And while it won't make an ounce more power, it does make the motor more responsive, so it feels more lively. It can also make fast upshifts a bit easier on synchros. And of course, there's the plain static weight reduction off the heavy end of the car. If you're already in there doing clutch work and want to make the car feel 'sportier', it's kind of a no brainer.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#30 |
not playing cards
Kind of like a turbo.
#31 |
Drives: 2017 manual BRZ
http://www.ft86speedfactory.com/exed...2013-ft86.html
* Racing flywheels are compatible with Stage 1 Organic, Stage 2 Sports and Stage 2 Racing clutches. |
#32 | |
Drives: 2017 Toyota 86
#33 | |
Yep, starting a model A JD on a cold morning had it's challenges. Set the gas, open the petcocks, set the choke, spin the flywheel ........ and hope the hell that sucker didn't flood before it started ...... not a job for the weak wristed. Oh, yes, nothing runs like a deere ..... What year was your model A .. ?? humfrz |
#34 |
Only happy when it rains.
Drives: series.blue
It is worth it in my opinion, doesn't really make it that much harder to drive.
#35 | |
got him when he retired as a mechanic after almost 30+years. I would pull the A it had more pow pow lol. If I rember it had duel fuel so kerosene and gas easier to start on gas but I think it ran longer on the kerosine although I could have that backwards. Man that takes me back.
#36 | |
The oldest tractor I remember was a 1940 something Oliver 70, with all steel wheels. Yep, that was a bitch to hand crank to start. I would set up a 5 gallon can beside the crank, set the crank, jump off the can onto the crank, remembering not to wrap my thumb around the crank handle and hope the hell I got my arm out of the way in case it kicked back ...... ![]() Welcome, folks to the .......... Old Tractor Channel ........ ![]() humfrz |
#37 |
Drives: Toyota GTS 86
You'll like it if you use auto-blip/heel-toe for downshifting. Rev matches much faster.
#38 | |
Drives: 2005 Toyota Camry
In other words: If the flywheel or clutch kit does not require you to get a matching pressure plate or flywheel to use with, you can use it. |
#39 | |
lol love the tractor channel hehe
#40 | |
| OEM Clutch And Flywheel with 14k. | nickmerronesucks | Transmission and Driveline | 15 | 10-22-2015 04:57 PM |
| WTB OEM clutch and flywheel | Opposed | Want-To-Buy Requests | 5 | 08-08-2014 01:47 AM |
| Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? | OICU812 | Engine, Exhaust, Transmission | 2 | 05-17-2014 01:56 AM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 10:01 AM |
