Old 12-04-2017, 06:50 PM   #29
toyubie
Drives: none
Originally Posted by dostoyevsky View Post
Ive been looking for this for quite a while! Thank you!
Is there anyway to make it like newer cars that If I pull the handle from the inside it auto unlocks?
Might be possible by adding a switch or sensor to the handle; AFAIK there's nothing to detect the handle has been pulled right now, but at that point you'e pulling off panels and running wires.
toyubie is offline   Reply With Quote
Old 12-05-2017, 01:35 PM   #30
T0rt0r0
Drives: European gt86
You are welcome
For the pull, I've never saw anything like this, could please be more precise ? (Maybe a specific car model that I could look into ?)
But if it needs extra sensors that the frs is not equiped with, you have your answer it's not possible
T0rt0r0 is offline   Reply With Quote
Old 12-05-2017, 01:53 PM   #31
spike021
spike021's Avatar
BMW's M2 (2017 MY I think?) has it. You pull twice on the door handle and it unlocks.
spike021 is offline   Reply With Quote
Old 12-05-2017, 02:32 PM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Thanks man, This is actually much better then the OBD2 thing most ppl are running.... Cuz I have an iphone LOL.
(aka only wifi with OBD2...means I don't have internet while running those apps that ppl trys to run)
Old 12-05-2017, 04:37 PM   #33
dostoyevsky
Drives: 2017 BRZ
My dodge dart had it :L
dostoyevsky is offline   Reply With Quote
Old 12-05-2017, 04:53 PM   #34
ermax
ermax's Avatar
This adapter works with iOS via BLE:
https://www.amazon.com/dp/B01MAURDGG
The key is to get the “Enhanced Version”. This version runs Bluetooth Serial Profile for Android but also runs Bluetooth LE for iOS connectivity. The description on this item fails to explain this but trust me it works. I have this version and it works great on my iPhone. I’ve tested it with Carista, DashCommand and Fusion. Fusion is the best hands down. Very similar to Torque. There is an in app upgrade that adds direct support for Toyota’s which gives it access to a ton of PIDs for our cars.
Old 12-06-2017, 01:31 PM   #35
T0rt0r0
Ok thanks I'll look into this when I'll have some time
But I don't remember any information about the door interior handle position so I think it will not be possible
Old 12-30-2017, 02:16 PM   #36
T0rt0r0
Not a lot a free time since my last post but did not forgot about improvements
Just to know, has anybody tried the code and succeeded ?
Old 01-30-2018, 12:31 PM   #37
ermax
ermax's Avatar
It would be interesting to know how you are reverse engineering Techstream. I would love to have access to the tire pressures.
Old 01-30-2018, 12:45 PM   #38
darko
Drives: RAVEN FRS
Could it be possible to close the windows when car ignition is turned off?
darko is offline   Reply With Quote
Old 01-30-2018, 03:08 PM   #39
T0rt0r0
I bought a obd y cable.
Plugged in the car and in a tactrix interface (for techstream) and in parrallel with my arduino board that just listened to the can trafic.
Then simply played with the diagnosis features of techstream and deduced the correct frames to use.
Not too hard but a lot of work when you don't really know what you are looking for
Is it doable with the windows switches just after you turn off ?
If yes it might be ok as I successfully played with the windows (but with ign on)
Old 02-19-2018, 12:13 PM   #40
ermax
ermax's Avatar
I just ordered an Arduino UNO R3, the CAN bus shield, serial to OBD2 and a Y cable. My goal is to capture the traffic coming from Techsteam when putting the VSC/TRAC/ABS system into "inspection mode" so I can have a more permanent way (toggle switch) to disable TC/VSC. But I will also have the ability to do other creative things. I saw where someone replaced the clock with a small LCD screen and repurposed the clock buttons for controls to the Arduino. This is going to be a fun project.
The Following User Says Thank You to ermax For This Useful Post:
Ultramaroon (03-30-2018)
Old 02-19-2018, 01:10 PM   #41
T0rt0r0
Great
Did not mess with the vsc system but you should be able to do what you want
Old 03-05-2018, 02:03 PM   #42
T0rt0r0
Just a quick update: I updated the code a little (better reliability of connexion initialization mostly) and changed the way the system is powered in the car.
Now the arduino is directly plugged in a +12v after ign with two 6800nF capacitors.
This way it has the time to open the doors if needed when turning ignition off and then do not draw any current.
This way no worries about the battery if the car is not driven enough.
I've been using this since a few months and some track days without an issue
The Following User Says Thank You to T0rt0r0 For This Useful Post:
Chimera (03-05-2018)
Auto locking doors Thavash AFRICA 21 02-12-2019 02:23 PM
Auto locking doors Magyarman Issues | Warranty | Recalls / TSB 13 01-23-2019 09:25 PM
Doors won't lock. mynameis940 Issues | Warranty | Recalls / TSB 9 03-15-2018 03:05 PM
Auto Lock (Doors) pinoyplaya BRZ First-Gen (2012+) — General Topics 67 11-13-2017 11:47 AM
Doors won't automatically lock adan Issues | Warranty | Recalls / TSB 18 03-01-2014 11:02 AM
