| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#29 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
another update regarding the high-idle issue. my TPS sensor will not calibrate into spec, and it appears to be the problem with my idle. spec is .4-.5V and mine will only adjust down to 1.6V or so.
i tested my coolant temp sensor, and it changed resistance according to spec, and has good power and ground. what i did notice was some corrosion buildup on the terminals on the ECTS and the harness connector. i cleaned the corrosion off and it seems to be working properly now. so it looks like i'll have to spend another $80 on a new TPS in addition to the $80 headlight switch. still fixed it right up for under $400, and it runs SO MUCH better now than when i got it, there's no comparison. completely different car now.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#30 | |
2.1L 3SGTE
my MR2 still takes priority, and will continue to do so until it's "finished." :happy0180:
#31 |
Drives: MR2
