#29 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
-O/D
2016 FR-S, Hot Lava |
#30 | |
Drives: 2017 86 Coupe
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter |
#31 |
Drives: '17 86
Currently no spoiler. I'm probably going to put the TRD spoiler on a little later. It's my daily but I've got a Suburban as well so not too worried about winter. Definitely going to upgrade the tires though.
#32 |
Drives: Toyota GT86 Coupe Red (UK)
Why is it the only people I hear complaining about the clutch is the North American guys?
Has to be something to do with you being a nation(s) of Auto drivers. Also new clutches are usually very light and stiffen up as the clutch springs age and harden. Much like guitar strings starting out loose and springy with a rich sound and going stiffer and deader as the metal hardens into it's new stretched shape. I think in the UK we are so used to jumping out of one manual into another that we just get used to clutches being different in different vehicles. Not just different models/brands, but different individual vehicles within the same model/brand feel different. I also expect it's a bit of "blame the tool" by those with limited clutch control ability. They get into an unfamiliar manual car and are a bit lurchy so it can't possibly be their lack of clutch control it must therefore be a problem with the clutch. (I'm bored at work so thought I'd start a bit of a war for lolz )
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#33 | |
The Gunshine State
Drives: '14 BRZ Limited
![]() Current DD: M235i |
#34 | |
Personally I consider the "spring" at the top as "slack", so I automatically depress the clutch through that "slack" to the where the actual force begins everytime I put my foot on the clutch. So my foot knows exactly where it is. If that's the "spring" you mean? I'm never really had much issue with the clutch. I do get the odd jerk as the clutch fully engages but usually when I'm being lazy and driving on full auto pilot. My foot muscle memory knows where the bite point is so well without applying throttle I can lift my foot straight from the floor to the bite point quick enough to make the drive train "thump" but not stall or even bog the engine. My performance launch without rev'ing is to do just that and then floor it and lift the clutch the rest of the way almost immediately. Results in a full throttle launch without breaking 1k rpm on clutch slip. Maybe the clutches are different across the pond? I know quite a few other things are different on each side of the atlantic.
#35 | |
The Gunshine State
#36 |
Sittin' Sideways
Aren't we actually talking about a physical spring in the assembly here?
-O/D
#37 | |
Drives: '17 86
I'm going to pull that spring out soon, maybe this weekend. I think it will help based on what I've read. |
#38 | |
![]() ![]() humfrz |
#39 | |
It was the same on my last cars too. If yours is far below that then maybe adjusting the master cylinder might be better than removing the spring?
#40 | |
The Gunshine State
I did both, remove spring and then re-adjust master cylinder (otherwise there's slack in the pedal).
#41 |
There is meant to be slack in the pedal. If you remove the slack you remove the tolerances for the clutch mechanism to change with wear and temperature.
#42 |
The Gunshine State
Have you removed the spring and adjusted the shaft? It's impossible to remove the slack 100%, what I'm saying is removing the excess that occurs after you remove the helper spring in order to get the slack back to OEM tolerances.
| Anything going on tonight | GotBRZ1691 | Northern California | 4 | 07-25-2014 11:49 PM |
| For those who ride, there's a group ride happening tomorrow if you're interested. | Yamaha_R6 | Northwest | 3 | 03-07-2014 09:32 PM |
| Tonight 3/9 | Memento | Southern California | 7 | 03-10-2013 12:49 AM |
| What's your other ride, winter ride etc. | wtout86 | Other Vehicles & General Automotive Discussions | 13 | 12-07-2012 12:36 AM |
