Old 06-29-2017, 07:57 PM   #29
radroach
Drives: car
Look into swapping in a lightweight racing fluid washer fluid. But be sure to fill it up all the way, having the front end so light might cause it to raise up like a drag car on acceleration.
The Following 2 Users Say Thank You to radroach For This Useful Post:
Tcoat (06-29-2017), Ultramaroon (07-01-2017)
Old 06-29-2017, 08:06 PM   #30
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
My washer fluid reservoir was empty for about 6 months, so I finally filled it and now my car over steers like crazy.
Did I throw off the weight balance from front to rear and have too much tread on my front tires from the lack of weight? Will rotating my tires fix this?
Easily corrected by fitting negative camber mudflaps.
Search before you ask next time.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Tcoat (06-29-2017)
Old 06-30-2017, 04:53 PM   #31
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Or front canards upside down
IceFyre13th is offline   Reply With Quote
Old 06-30-2017, 06:24 PM   #32
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Better either full or empty than only half full.
If half full it will slosh around at every turn and could cause snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer,then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer, then serious understeer, then snap oversteer,
Shouldn't there be a torque dip in the middle of this?
Tcoat (06-30-2017)
Old 07-01-2017, 12:33 AM   #33
navanodd
Drives: 2013 BRZ Sport-tech WRB
No, of course everyone knows torque dip is more of a topping.
navanodd is offline   Reply With Quote
The Following 2 Users Say Thank You to navanodd For This Useful Post:
guybo (07-01-2017), Tcoat (07-01-2017)
Old 07-01-2017, 02:56 AM   #34
radroach
Drives: car
On a side note I downloaded too much data and the server got too heavy
Old 07-01-2017, 08:56 AM   #35
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Wouldn't downloading data make the server lighter?
I don't know much about servers though, except I don't like to tip them. So you may be correct.
Old 07-01-2017, 02:14 PM   #36
humfrz
That's hard to believe ..... what's your download speed, with dial up ... there in Tennessee ..... ??
humfrz
Old 07-01-2017, 03:17 PM   #37
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I filled up my jizzer fluid bottle and it the handling was so bad I had to do a grill delete. I don't know what I'm going to have to delete when I replace my battery
Old 07-01-2017, 04:19 PM   #38
humfrz
You should have only deleted the drivers side part of the grill .....
Where ever did common sense go ......
humfrz
Old 07-01-2017, 06:03 PM   #39
guybo
Huge E85 fan!
guybo's Avatar
fuuuuuck, that explains the extra wear on the right side tires. Down to the belts, almost.
The Following User Says Thank You to guybo For This Useful Post:
humfrz (07-01-2017)
Old 07-01-2017, 06:53 PM   #40
Ultramaroon
not playing cards
Ultramaroon's Avatar
No it doesn't. It would if it was the left side.
Corner balance. You move the battery down to the washer bottle.
Old 07-01-2017, 07:49 PM   #41
Andrew025
Andrew025's Avatar
But then you have to compensate for all that extra electricity on that corner too.
Move spare tire to front bumper.
Old 07-01-2017, 08:13 PM   #42
We really need Gforce to weigh in on this.
No doubt he can tell us exactly what needs to be placed where.
Andrew025 (07-01-2017), Ultramaroon (07-01-2017)
Washer fluid not spraying out btan219 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 09-16-2019 05:35 PM
Washer fluid tank, need to fix asap. SavingManuals Electronics | Audio | NAV | Infotainment 0 11-22-2015 06:12 PM
Window washer fluid light? husker741 Scion FR-S / Toyota 86 GT86 General Forum 14 10-20-2013 12:15 PM
Washer Fluid Indicator Tdot BRZ First-Gen (2012+) — General Topics 58 02-19-2013 04:02 PM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 04:18 PM
