Old 06-22-2017, 09:01 PM   #29
humfrz
Originally Posted by Scrappydoo View Post
Has the OP checked for water in the fluid reservoir.?
Not being facetious but I'm getting a bit jaded by the dimfuck posts on here.
May I refer you to post number one, oh jaded one .......
humfrz
Old 06-22-2017, 09:07 PM   #30
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
humfrz
Put the fluid in the right container i hope.
#beyondjaded.
Old 06-22-2017, 09:16 PM   #31
humfrz
#beyondjaded.
Well, I should hope that he put the fluid in the right container ...... after all, the cap for it has a nice imprint picture on it.
If he put the windshield washer fluid in the radiator reservoir by mistake, we should recommend that he do no more DIY work on his car.
Hey, you related to @Scrappydoo ......
humfrz
PS - is the Pineapple Research Institute still active in Wahiawa .. ?? Back in the day, I visited there, once a year for several years.
Old 06-23-2017, 04:13 AM   #32
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
What was the diagnosis?
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
humfrz (06-23-2017)
Old 06-23-2017, 04:21 AM   #33
gramicci101
Off Topic
He determined that pineapples are not, in fact, apples. Nor are they related to pine trees. The research staff were probably confused on how he kept getting past security and into the building.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
Grady (09-16-2019), roddy (06-24-2017), Scrappydoo (06-23-2017), ShadowReaper (08-30-2022)
Old 06-23-2017, 08:38 AM   #34
jasonojordan
Drives: 2013 satin white brz limited
Originally Posted by btan219 View Post
http://imgur.com/a/kaEgo
I disconnected the two lines but nothing still came out
I am not sure if this will work or not but possibly worth a shot. Open the lid to the tank. Disconnect the line at the joint on the fender. Gently blow some air back through the line. Provided that there is not a check somewhere in the system this should back flush any clogs in the pump in the line. Could possibly work. Once again never tried it before myself so do so at your own risk.
jasonojordan is offline   Reply With Quote
The Following 3 Users Say Thank You to jasonojordan For This Useful Post:
humfrz (06-23-2017), roddy (06-24-2017), Tcoat (06-24-2017)
Old 06-23-2017, 02:45 PM   #35
btan219
Drives: DGM 15' BRZ Limited
Yup I did top off the washer fluid in the correct container (that much I know how to do). Thanks guys, I'll try out other methods that were suggested here!
btan219 is offline   Reply With Quote
The Following User Says Thank You to btan219 For This Useful Post:
Tcoat (06-24-2017)
Old 06-23-2017, 10:44 PM   #36
humfrz
They never did figure it out ......
The local hekikai no said that he had a special pineapple dust that would cure me. He was wrong!
They sent me back to the mainland for treatment and restricted my visits to once per year......
humfrz
Scrappydoo (06-24-2017), Tcoat (06-24-2017)
Old 06-23-2017, 10:46 PM   #37
humfrz
WOW! ....... old school ......
humfrz
roddy (06-24-2017)
Old 09-16-2019, 06:35 PM   #38
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Does anyone know the part number for the plastic sprayer nozzle? Also what is the proper way to remove it? I thought I'd ask before I bust out the needle nose and rip that sob out.
DandoX is offline   Reply With Quote
Washer fluid tank, need to fix asap. SavingManuals Electronics | Audio | NAV | Infotainment 0 11-22-2015 07:12 PM
Window washer fluid light? husker741 Scion FR-S / Toyota 86 GT86 General Forum 14 10-20-2013 01:15 PM
Washer Fluid Indicator Tdot BRZ First-Gen (2012+) — General Topics 58 02-19-2013 05:02 PM
Deos this car not warn you when you are low on washer fluid? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 28 02-07-2013 01:00 AM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 05:18 PM
