Old 06-18-2017, 10:03 PM   #29
-Willis-86touge
Drives: Stock
So I'm curious? In for an upgrade and I think I'm going ebc yellow stuff. Anybody tried them? Maybe also thinking of a rotor upgrade. Are the cheap slotted eBay rotors bad like Eline or power slot? Are they just as good a stock because they say oem spec in the descriptions? Anybody tried them?
-Willis-86touge is offline   Reply With Quote
Old 06-18-2017, 10:38 PM   #30
strat61caster
strat61caster's Avatar
Slotted/drilled rotors are not an "upgrade" stick with blank rotors for this car. Centric's are cheap on Amazon (~$40 ea) and track guys love 'em.
Yellow Stuff have mixed reviews depending on your purpose, hardcore track usage they probably won't hold up. "spirited driving in the twisties" () they might be fine if a little noisy and dusty. There's tons of reviews on them if you have the patience to google for them.
ineedyourdiddly
Old 06-18-2017, 10:45 PM   #31
-Willis-86touge
Drives: Stock
Thanks for the reply
Old 06-19-2017, 03:57 AM   #32
churchx
churchx's Avatar
Drives: 2014 GT86
As far as reliability goes blank > slotted > drilled > drilled and slotted. On track reliability matters so much more, so +1 to what strat61caster wrote, best bet would be blank disks, or not more then slotted ones. If you need more bite, better use more oriented track pads, then compromising reliability/upping chances of cracking under heavy abuse.
From not that cheap stuff there are also DBA disks. IIRC one could get even two piece ones of OE sizing.
BTW, if you think of getting most out of OEM brakes, worth considering installing airducts. Extra cooling may help with increasing heat capacity of even stockers. For example something like Velox/Touge Factory/APR kits.
Old 06-19-2017, 12:04 PM   #33
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Gforce View Post
B. S.
Excellent argument.
Old 06-19-2017, 03:50 PM   #34
Gforce
Drives: 2013 Subaru BRZ
"For normal usage conditions, the design*life of the front wheel brake discs should be equivalent to the useful life of two sets of*corresponding brake pads. Some discs may have a shorter useful life, because they*have been designed to achieve specific targets."
NORMAL driving. That does not mean driving it as a Prius it means driving it as it should be on the public streets.
You said one I said 3 your own link puts it in the middle.
Of course, each driver has to make his or her own decision.
Years ago I decided turning rotors was a waste of time and money. So I fit new rotors with new pads. Car makers agree. They now fit rotors that are designed to minimum safe weight intended for one set of pads.
If you fit new pads to worn rotors you are wasting money and putting up with second rate brakes.
Up to you, of course.
Gforce is offline   Reply With Quote
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 05:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 06:53 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 05:52 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 01:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
